EPL.01.250.DLN
EPL.01.250.DLN
    LEMO(雷莫)
    插件
    EPL.01.250.DLN
EPL.01.250.DLN 数据手册
EPL.01.250.DLN www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 01 Termination type Female print PCB IP rating 50 AWG wire size 0.00 - 0.00 PCB Altium Pattern Cable Ø 0.00 - 0.00 mm PCB KiCad Pattern Status active Catalog Matching parts FFS.01.250.DLAE31 Download Request a quote PCB Eagle Pattern TECHNICAL DETAILS Mechanics Shell Style/Model EPL.01*: Elbow receptacle for printed circuit Keying Circular, female Housing Material Brass (gold plated [ISO 27874]) shell, collet nut, brass latch sleeve and mid pieces Weight 3.17 g Performance Configuration 01.250 : 1 Coax (50 Ohm) Insulator Rated Current Others Endurance (Shell): 1000 mating cycles LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 DRAWINGS Dimensions A B C D L M N mm. 6 6 6 10 12.5 8.5 3 in. 0,24 0,24 0,24 0,39 0,49 0,33 0,12 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
EPL.01.250.DLN 价格&库存
很抱歉,暂时无法提供与“EPL.01.250.DLN”相匹配的价格&库存,您可以联系我们找货
