PL71-P-1.5CW(40)
PL71-P-1.5CW(40)
    HRS(广濑)
    CONN RF COAXIAL
PL71-P-1.5CW(40) 数据手册
Push-on Lock Coaxial Connectors for Digital Broadcasting Applications PL71 Series 75Ω Up to 3 GHz ■Features 1. 20% downsized compared with conventional 75 ohm BNC connectors. 2. Superior locking mechanism Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Our exclusive locking method keeps the mating part in constant contact with the electr ic reference plane (Top Touch), ensuring high contact stability and reliability. The construction is protected by the outer shell. 3. Stable, stationary center contact structure The stationary design protects the extremely thin center conductor of this 75 ohm coaxial cable from potential damage. Damage can be caused by rotational forces during mating and unmating. 4. Reliable at high frequencies The high-frequency performance of the PL71 S e r i e s i s ve r y r e l i a bl e, w i t h V. S. W. R . characteristics of a maximum of 1.3 at DC, and up to 3 GHz, which is suitable for 3G-SDI broadcasting equipment. ■Applications The PL71 Series is well suited for use in the digital cable television broadcasting industry. This 75 ohm coaxial series can work together with BNC(75)Series and PO82M Series to configure a wide range of functions, including interface connections, plug-in mounting, and wiring within devices. Inner Wiring¤PL71 Series Plug-in mounting¤PO82M Series Interface→BNC(75)Series Housing is compliant with IEC61076-4-101 ¤PO21M Series ■Mating Chart Plugs Straight PL71-P-πππ Right-angle PL71-LP-πππ Receptacles Straight PL71-R-PC Right-angle PL71-LR-PC In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2014.11w 1 PL71 Series●Push-on Lock Coaxial Connectors for Digital Broadcasting Applications Specifications Nominal characteristic impedance Frequency range : DC to 3 GHz Ratings Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item 1. Contact resistance 2. Insulation resistance 3. Withstanding voltage 4. V.S.W.R. 5. Center contact 6. Insertion and withdrawal forces 7. Durability(mating/ unmating with corresponding plug) : 75ø Operating temperature range :-30°C to +85°C Operating humidity : RH 95% max. Specification 6 mø max. 1,000 Mø min. No flashover of insulation breakdown 1.3max. 0.5N min. Conditions 100 mA max. 500 V DC 500 V AC / 1 minute DC to 3 GHz Measured with 0.49mm diameter pin gauge 9.8 N min. Measured with the applicable mating pair Contact resistance 6 mø max. 500 mating cycles Frequency: 10 to 500 Hz, single amplitude of 2 0.75 mm, acceleration of 98m/s , 10 cycles in each of the 3 axial directions 2 Acceleration of 490m/s , for a duration of 11 ms, sine half-wave waveform, 3cycles in each of the 3 axial directions 8. Vibration No electrical discontinuity of 1μs or longer No damage, cracks, or parts dislocation 9. Shock resistance No electrical discontinuity of 1μs or longer No damage, cracks, or parts dislocation 10. Moisture resistance Insulation resistance: 100 Mø min. (high humidity) Insulation resistance: 1,000 Mø min. (dry) No damage, cracks, or parts dislocation 240 hours at +25ç to +65ç and humidity of 80% to 96% 11. Temperature cycle No damage, crack, or part dislocation Temperature:-55ç ➝ +5ç to +35ç ➝ +85ç ➝ +5ç to +35ç Time: 30 min. ➝ 5 min.max. ➝ 30 min.➝ 5 min.max. 5 cycles 12. Salt spray No corrosion 5% salt water solution, 48 hours Note: Some products may have different specifications from those shown above. Please confirm requirements before ordering. Materials Part Materials Finish Remarks Shell Brass Nickel plated ––– Male center contact Brass Gold plated ––– Female center contact Beryllium copper Gold plated ––– Insulator PTFE ––– Flame retardant Ordering information PL71 q 2 w e : PL71 q Series name Connector type w P : Straight plug LP : Right-angle plug R : Straight receptacle LR : Right-angle receptacle Applicable cable(plug) or board e 1.5C : 1.5C-QEV.CW 1.5CW : 1.5C-QEW.CW PC : DIP mounting PL71 Series●Push-on Lock Coaxial Connectors for Digital Broadcasting Applications Plugs Ø7 Ø6.5 Straight 20.7 All dimensions:mm HRS No. Applicable cable PL71-P-1.5CW(40) 334-0001-5 40 1.5C-QEW.CW PL71-P-1.5CV-1(40) 334-0069-9 40 1.5C-QEV.CW RoHS Yes Right angle 14.4 Ø6.5 6.7 14 All dimensions:mm Part No. HRS No. Applicable cable PL71-LP-1.5CW(40) 334-0006-9 40 1.5C-QEW.CW PL71-LP-1.5C(40) 334-0007-1 40 1.5C-QEV.CW RoHS Yes Receptacles Straight PCB mounting pattern 5.08±0.05 2.54±0.05 4∞Ø 1.2± 0.1 Ø0.8 +0 .1 0 2.54±0.05 5.08±0.05 Ø3.95 8.5 5.08 5.7 Ø0.7 2.9 All dimensions:mm Part No. HRS No. RoHS PL71-R-PC(40) 334-0011-9 40 Yes Right angle PCB mounting pattern 5.7 10.2 5.08±0.05 4∞Ø 1.2± Ø0.8 +0 0 0.1 .1 2.54±0.05 Ø0.7 5.08 5.08±0.05 Ø3.95 4.65 7.65 2.54±0.05 2.5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. All dimensions:mm Part No. HRS No. RoHS PL71-LR-PC(40) 334-0016-2 40 Yes 3 PL71 Series●Push-on Lock Coaxial Connectors for Digital Broadcasting Applications High Frequency Characteristics of 75Ω Hirose product series BNC(75) Series 2 1.9 100 1.8 V.S.W.R. 1.7 1.6 1.5 1.4 1.3 BNC(75)-BPJ-1.5CV-π BNC(75)-BPJ-1.5CV-π 1.2 1.1 1 0 0.5 1 1.5 2 2.5 3 2 2.5 3 2 2.5 3 2 2.5 3 Frequency[GHz] Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PL71 Series 2 1.9 100 1.8 V.S.W.R. 1.7 1.6 1.5 1.4 1.3 BNC(75)-BPJ-1.5CV-π PL71-LP-1.5C(40) 1.2 1.1 1 0 0.5 1 1.5 Frequency[GHz] PL75 Series 2 1.9 100 1.8 V.S.W.R. 1.7 1.6 1.5 1.4 1.3 BNC(75)-BPJ-1.5CV-π PL75-LP-1.5CV 1.2 1.1 1 0 0.5 1 1.5 Frequency[GHz] H.FL75 Series 2 1.9 1.8 H.FL75-2LPG-084Nπ-L V.S.W.R. 1.7 100 1.6 1.5 1.4 1.3 1.2 1.1 BNC(75)J-H.FLJ-BPA(40) 1 0 0.5 1 1.5 Frequency[GHz] ® 4 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 11/2014. Contents are subject to change without notice for the purpose of improvements.
PL71-P-1.5CW(40) 价格&库存
很抱歉,暂时无法提供与“PL71-P-1.5CW(40)”相匹配的价格&库存,您可以联系我们找货
