FLC.00.250.CTAC29
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
00
Termination type
Male solder
IP rating
50
AWG wire size
0.00 - 0.00
Cable Ø
2.80 - 3.10 mm
Status
active
Matching parts
ERA.00.250.CTL
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FLC*: Elbow (90°) plug with cable collet
Keying
Circular, male
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
3.87 g
Performance
Configuration
00.250 : 1 Coax (50 Ohm)
Insulator
T: PTFE
Rated Current
4 Amps
Specifications
Contact Type: Coaxial 50 Ohm (Solder)
Contact Dia.: 0.7 mm (0.028in)
Bucket Dia.: 0.6 mm (0.024in)
Test voltage: 2.1 kV (rms)
R (max): 6.1 mOhm
Vtest: 2100 V (AC), 3000 V (DC)
Impedance: 50 Ohm
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
VSWR: 1.09 + 0.11 * f/GHz
Others
Endurance (Shell): 5000 mating cycles
F ret (min): 100 N
Salt Spray Corrosion: >1000 hr
DRAWINGS
Dimensions
A
H
L
M
S1
S2
mm.
7.5
16.7
19.5
11.5
4.5
6
in.
0,30
0,66
0,77
0,45
0,18
0,24
RECOMMENDED BY LEMO
Tools
Cables
17420
PVC
Black
31600
PTFE
Brown
2/3
CCX.50.RG1.74AU28N
PVC
Black
CCX.50.RG1.74AU28N
PVC
Black
CCX.50.RG3.16U28M
PTFE
Brown
3/3
很抱歉,暂时无法提供与“FLC.00.250.CTAC29”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+188.7185150+24.43125
