SF1621-60026
SF1621-60026
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONN2.4MMJACKSTR50OHMSOLDER
SF1621-60026 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION DATE APPROVED - NRN 40059 12/15 STW A DCN 43120 02/17 STW REV PRODUCT DATA DRAWING .440 11.18 .222 5.64 .065 1.65 A .282 7.16 .400 10.16 M7 X .75-6g 2X 0-80 UNF-2B MATERIAL: BODY & INSERT: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: POLYETHERIMIDE RESIN (ULTEM 1000) .003±.001 0.08±0.03 .020±.001 0.51±0.03 DETAIL A FINISH: BODY & INSERT: PASSIVATED PER AMS-2700 CONTACT: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: FREQ. RANGE: NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: 50 OHMS DC TO 50.0 GHz N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: BNK 10/22/14 CHECKED: APPROVED: STW 10/22/14 STW 10/22/14 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: 2.4mm JACK 2-HOLE FLANGE MOUNT W/ MOUSE HOLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 7:1 SF1621-60026 SHEET 1 OF 1
SF1621-60026 价格&库存
很抱歉,暂时无法提供与“SF1621-60026”相匹配的价格&库存,您可以联系我们找货
SF1621-60026
  • 1+445.099621+57.65597
  • 10+378.2969710+49.00269
  • 25+354.6195025+45.93563
  • 50+337.7074850+43.74493
  • 100+321.60404100+41.65897
  • 300+297.65018300+38.55611
库存:362
