FFA.0S.250.CTAC42
FFA.0S.250.CTAC42
    LEMO(雷莫)
    FFA.0S.250.CTAC42
FFA.0S.250.CTAC42 数据手册
FFA.0S.250.CTAC42 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 0S Termination type Male solder Coaxial IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 3.80 - 4.40 mm Status active Alternative part FFA.0S.250.CTAC44 Matching parts ERA.0S.250.CTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug, cable collet Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 7.78 g Performance Configuration 0S.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 6 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 1 mm (0.039in) Vtest: 3000 V (AC), 4200 V (DC) Impedance: 50 Ohm VSWR: 1.02 + 0.25 * f/GHz Cable type: RG 178 B/U, RG 196 A/U, RG 188 A/U, RG 316 B/U, RG 174 A/U, HF-2114, RG 122 /U LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A L M S2 mm. 9 34.5 24.5 6.5 in. 0,35 1,36 0,96 0,26 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.0S.ZZZ.PA065 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.0S.250.CTAC42 价格&库存
很抱歉,暂时无法提供与“FFA.0S.250.CTAC42”相匹配的价格&库存,您可以联系我们找货
