FAA.00.650.NLA
FAA.00.650.NLA
    LEMO(雷莫)
    FAA.00.650.NLA
FAA.00.650.NLA 数据手册
FAA.00.650.NLA www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 00 Termination type Male solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts ELF.00.650.NLL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FAA*: Fixed plug, non-latching, nut fixing Keying Circular, male Housing Material Brass (nickel plated [SAE AMS QQ N 290]) shell, collet nut, latch sleeve and mid pieces Weight 2.65 g Performance Configuration 00.650 : 1 Triax (50 Ohm) Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 3 Amps Specifications Contact Type: Triaxial 50 Ohm (Solder) Contact Dia.: 0.5 mm (0.02"in) Vtest: 1200 V (AC), 1700 V (DC) Impedance: 50 Ohm VSWR: 1.1 + 0.11 * f/GHz Others Endurance (Shell): 5000 mating cycles LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Salt Spray Corrosion: >144 hr DRAWINGS Dimensions A L mm. 8 15.5 in. 0,31 0,61 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
FAA.00.650.NLA 价格&库存
很抱歉,暂时无法提供与“FAA.00.650.NLA”相匹配的价格&库存,您可以联系我们找货
