138-4403-107
    CINCH
    CONN N PLUG R/A 50 OHM SOLDER
138-4403-107 数据手册
Type N Right Angle Plug Crimp Style for RG-316, 316DX, 58, and 142 Flexible Cable 1. Identify connector parts. (3 piece parts) 2. Strip cable to dimensions shown. Do not nick center conductor. A wire stripper of correct size is recommended for this step. Twist stranded center conductor into tight bundle and tin (optional). Slide crimp sleeve onto jacket of cable. 3. Flare braid and slide plug connector assembly over cable dielectric and under braid. Make sure cable dielectric bottoms against plug contact as shown. Solder center conductor to contact through rear access port. Use a minimum amount of solder for a full fillet joint. 4. Arrange braid uniformly around crimp stem. Slide crimp sleeve forward and crimp using Johnson ergonomic hand crimp frame 1400000-967 with recommended hex size die set. Screw end cap into access port. Cable Group Part No. Crimp Sleeve Contact Hex Size Crimp RG-316/U, 161, 174, 188 138-4403-107 .755 (19.18) .128 (3.25) RG-316 DS, 188 DS 138-4404-107 .755 (19.18) .151 (3.84) RG-58/U, 141, 303 138-4407-107 .788 (20.02) .213 (5.41) RG-55/U, 142, 223, 400 138-4408-107 .788 (20.02) .213 (5.41) Assembly Tool 138-4403/4404/4407/4408-107 Crimp Frame 140-0000-967 Die Set 1140-0000-990 264 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
138-4403-107 价格&库存
很抱歉,暂时无法提供与“138-4403-107”相匹配的价格&库存,您可以联系我们找货
