138-4693-001
138-4693-001
    CINCH
138-4693-001 数据手册
Type N Straight Plug Solder Style for Semi-Rigid Cable 1. Identify connector parts (2 piece parts) and tools (5 piece parts). 2. Strip cable jacket and dielectric to dimension shown. Do not nick center conductor. Clean all debris from cable. 3. Place plug contact onto center conductor, insert appropriate sized solder shim between cable jacket and contact. 4. Insert contact into location fixture and clamp cable in vise. Tighten stop screw until light pressure is applied between contact, solder shim and cable jacket. 5. Solder contact to center conductor through solder hole using .020 (.051) diameter flux core solder wire. Use a minimum amount of solder for a good joint. 6. After solder joint has cooled, loosen stop screw and remove solder shim. Remove cable from vise and remove any excess solder from contact with a sharp blade and clean all debris from contact and cable. 7. Insert contact and cable into plug connector assembly, making sure cable jacket bottoms out against internal shoulder of connector assembly. Insert location fixture into connector assembly and clamp cable in vise. Tighten stop screw until light pressure is applied between connector assembly and cable jacket. 8. Solder connector body to cable jacket, using a minimum amount of solder for a full fillet joint. Allow assembly to cool before removing connector from vise. Cable Group Part No. “A” RG-405, .086 Semi-Rigid 138-4693-001 .085 (2.16) RG-402, .141 Semi-Rigid 138-4694-001 .085 (2.16) RG-401, .250 Semi-Rigid 138-4696-001 .100 (2.54) Assembly Tool 138-4693-001 138-4694-001 138-4696-001 Solder Shim 140-0000-984 140-0000-984 140-0000-985 Location Fixture 140-0000-983 140-0000-983 140-0000-983 Cable Vise 140-0000-962 140-0000-962 140-0000-962 Clamp Inserts 140-0000-964 140-0000-965 140-0000-986 266 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
138-4693-001 价格&库存
很抱歉,暂时无法提供与“138-4693-001”相匹配的价格&库存,您可以联系我们找货
