FFA.0A.250.CTAC29Z
FFA.0A.250.CTAC29Z
    LEMO(雷莫)
    FFA.0A.250.CTAC29Z
FFA.0A.250.CTAC29Z 数据手册
FFA.0A.250.CTAC29Z www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 0A Termination type Male solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 2.50 - 2.80 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug with cable collet and nut for fitting a bend relief Keying Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 9.26 g Performance Configuration 0A.250 : 1 Coax (50 Ohm) Insulator Rated Current Specifications Contact Type: Coaxial 50 Ohm (Solder) Others Endurance (Shell): 5000 mating cycles Salt Spray Corrosion: >1000 hr LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 DRAWINGS Dimensions A B L M S1 S2 mm. 9 9 37 27.5 7.5 7 in. 0,35 0,35 1,46 1,08 0,30 0,28 RECOMMENDED BY LEMO Tools Cables 17420 PVC Black 17450 COPOLYMER Black 18700 PTFE White 18800 PTFE White 31600 PTFE Brown CCX.50.RG1.74-U25N PVC Black CCX.50.RG1.74AU28N PVC Black CCX.50.RG1.74AU28N PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 CCX.50.RG1.74U25N PVC Black CCX.50.RG1.88AU26B PFA White CCX.50.RG1.88AU26B PTFE White CCX.50.RG3.16BU26M FEP Brown CCX.50.RG3.16U28M PTFE Brown CCX.75.RG1.79BU26M FEP Brown CCX.75.RG1.87AU26B PFA White CCX.75.RG1.87AU27B PTFE White LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.0A.250.CTAC29Z 价格&库存
很抱歉,暂时无法提供与“FFA.0A.250.CTAC29Z”相匹配的价格&库存,您可以联系我们找货
