FFC.00.250.CTAD52
FFC.00.250.CTAD52
    LEMO(雷莫)
    CONN PLUG STR 50 OHM SOLDER
FFC.00.250.CTAD52 数据手册
FFC.00.250.CTAD52 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 00 Termination type Male solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 4.10 - 5.00 mm Status active Matching parts ERA.00.250.CTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFC*: Straight plug with flats on latch sleeve and oversize cable collet Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 5.18 g Performance Configuration 00.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 4 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.6 mm (0.024in) Test voltage: 2.1 kV (rms) R (max): 6.1 mOhm Vtest: 2100 V (AC), 3000 V (DC) Impedance: 50 Ohm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 VSWR: 1.09 + 0.11 * f/GHz Cable type: RG 58 C/U Others Endurance (Shell): 5000 mating cycles F ret (min): 100 N Salt Spray Corrosion: >1000 hr DRAWINGS RECOMMENDED BY LEMO Tools Spanner wrench: DCD.00.ZZZ.PA050 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
FFC.00.250.CTAD52 价格&库存
很抱歉,暂时无法提供与“FFC.00.250.CTAD52”相匹配的价格&库存,您可以联系我们找货
