FFA.0A.250.CTAC27
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
0A
Termination type
Male solder
IP rating
50
AWG wire size
0.00 - 0.00
Cable Ø
2.20 - 2.60 mm
Status
active
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FFA*: Straight plug with cable collet
Keying
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
9.07 g
Performance
Configuration
0A.250 : 1 Coax (50 Ohm)
Insulator
Rated Current
Specifications
Contact Type: Coaxial 50 Ohm (Solder)
Others
Endurance (Shell): 5000 mating cycles
Salt Spray Corrosion: >1000 hr
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
DRAWINGS
Dimensions
A
L
M
S1
S2
mm.
9
33.5
24.5
7.5
8
in.
0,35
1,32
0,96
0,30
0,31
RECOMMENDED BY LEMO
Tools
Cables
18800
PTFE
White
CCX.50.RG0.58AU14B
FEP
White
CCX.50.RG1.74-U25N
PVC
Black
CCX.50.RG1.74U25N
PVC
Black
CCX.50.RG1.88AU24B
TFE
White
CCX.50.RG1.88AU26B
PFA
White
CCX.50.RG1.88AU26B
PTFE
White
CCX.50.RG3.16BU26M
FEP
Brown
CCX.75.RG1.79BU26M
FEP
Brown
2/3
CCX.75.RG1.87AU26B
PFA
White
3/3
很抱歉,暂时无法提供与“FFA.0A.250.CTAC27”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+175.21567100+22.66682
