ECP.00.650.NLL
www.lemo.com
SUMMARY
# Wires
Triax
1
Image is for illustrative purpose only
Series
00
Termination type
Female solder
IP rating
50
AWG wire size
0.00 - 0.00
Cable Ø
0.00 - 0.00 mm
Status
active
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
ECP*: Fixed receptacle with two nuts (back panel mounting)
Keying
Circular, female
Housing Material
Brass (nickel plated [SAE AMS QQ N 290]) shell, collet nut, latch sleeve and mid pieces
Weight
3.12 g
Performance
Configuration
00.650 : 1 Triax (50 Ohm)
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
3 Amps
Specifications
Contact Type: Triaxial 50 Ohm (Solder)
Contact Dia.: 0.5 mm (0.02"in)
Vtest: 1200 V (AC), 1700 V (DC)
Impedance: 50 Ohm
VSWR: 1.1 + 0.11 * f/GHz
Others
Endurance (Shell): 5000 mating cycles
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/2
Salt Spray Corrosion: >144 hr
DRAWINGS
Dimensions
A
B
E
L
M
N
S1
S3
e
mm.
10
9.5
4.3
13.7
2.5
13.7
6.3
9
M7x0.5
in.
0,39
0,37
0,17
0,54
0,10
0,54
0,25
0,35
RECOMMENDED BY LEMO
Tools
Spanner 2:
DCH.91.101.PA
Spanner wrench:
Socket for torque wrench DCM.00.M07.4
2/2
很抱歉,暂时无法提供与“ECP.00.650.NLL”相匹配的价格&库存,您可以联系我们找货
