ROHS COMPLIANT
PRODUCT DATA DRAWING
REVISION HISTORY
DESCRIPTION
REV
A
DCN 41836
DATE
APPROVED
11/15
STW
.500 12.70
.343 8.71
.157 3.99
.240 6.10
O-RING
.050 1.27
.202±.002 5.13±0.05
2X.200 5.08
2X .200 5.08
NOTES:
1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE
CONTACT US AT applications@svmicro.com
MATERIAL:
BODY:
STAINLESS STEEL PER AMS-5640,
ALLOY UNS S30300, TYPE 1
CONTACT:
BRASS PER ASTM B16, ALLOY UNS No. C36000
INSULATOR:
PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B
O-RING:
FLUOROCARBON RUBBER PER AMS 7276
GOLD PER ASTM B488, TYPE II,
CODE C, CLASS .076, OVER NICKEL
PER AMS-QQ-N-290, CLASS 1, .00005" MIN.
MATERIAL:
FINISH:
SEE NOTES
SEE NOTES
SURFACE AREA:
PERFORMANCE:
IMPEDANCE:
.0685±.0015 1.74±0.04
RECOMMENDED MOUNTING HOLE
FINISH:
BODY &
CONTACT:
4X
.062 1.57
N/A
PROPRIETARY
50 OHMS
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
.030
.010
.005
ANGULAR: X
X X'
1 0'
15'
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
MEB 10/02/02
CHECKED:
APPROVED:
STW 10/02/02
STW 10/02/02
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
BMA PLUG
RECEPTACLE
SIZE CAGE CODE DWG. NO.
B
95077
SCALE: 8:1
1785-6001
SHEET 1 OF 1
很抱歉,暂时无法提供与“1785-6001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+363.11650100+47.03629
