PRODUCT DATA DRAWING
REVISION HISTORY
DESCRIPTION
DATE
APPROVED
DCN 37960
01/11
STW
A
REV. DCN 50969
08/16/21
STW
REV
.320 8.13
4X
.030±.002 0.76±0.05
.150 3.81
2X .100±.002 2.54±0.05
RP
.033±.001 0.84±0.03
.164 4.17
.090 2.29
RECOMMENDED MOUNTING HOLE PATTERN
NOTES:
1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE
CONTACT US AT applications@svmicro.com
4X .096 2.44
MATERIAL:
INTERFACE BODY:
.024±.001 0.61±0.03
STAINLESS STEEL PER AMS 5640, ALLOY S30300, TYPE 1
OR ASTM A582, TYPE 303, CONDITION A.
PC LEG BODY &
CONTACT:
BERYLLIUM COPPER PER ASTM B196, ALLOY C17300, TD04.
INSULATOR:
PTFE PER ASTM D1710
4X
FINISHES:
INTERFACE BODY:
GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27
OVER NICKEL PER AMS 26074, CLASS 1, .000050" MIN.
CONTACT:
OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .000050" MIN.
MATERIAL:
PERFORMANCE:
IMPEDANCE:
FREQ. RANGE:
V.S.W.R.:
D.W.V.:
INSULATION RES.:
2X
.100±.002 2.54±0.05
PASSIVATED PER AMS 2700.
PC LEG BODY:
FINISH:
50 OHMS
DC TO 20 GHz
1.35:1 DC TO 20 GHz
500 VRMS
5,000 MEGOHMS MINIMUM
.020 0.51
SEE NOTES
SEE NOTES
SURFACE AREA:
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
.030
.010
.005
ANGULAR: X
X X'
1 0'
15'
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
SV Microwave, Inc.
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
FED 01/18/11
CHECKED:
APPROVED:
STW 01/18/11
STW 01/18/11
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
SMP MALE L.D. R/A
4-LEG PCB MOUNT
SIZE CAGE CODE DWG. NO.
B
95077
SCALE: 13:1
SF1212-6001
SHEET 1 OF 1
很抱歉,暂时无法提供与“SF1212-6001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+373.37692100+48.23739
