PCA.00.250.CTLK42Z
PCA.00.250.CTLK42Z
    LEMO(雷莫)
    PCA.00.250.CTLK42Z
PCA.00.250.CTLK42Z 数据手册
PCA.00.250.CTLK42Z www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 00 Termination type Female solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 3.30 - 4.10 mm Status active Matching parts FFA.00.250.CTAK42Z Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model PCA*: Free receptacle with oversize cable collet and nut for fitting a bend relief Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 6.57 g Performance Configuration 00.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 4 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.6 mm (0.024in) Test voltage: 2.1 kV (rms) R (max): 6.1 mOhm Vtest: 2100 V (AC), 3000 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Impedance: 50 Ohm VSWR: 1.09 + 0.11 * f/GHz Others Endurance (Shell): 5000 mating cycles F ret (min): 100 N Salt Spray Corrosion: >1000 hr DRAWINGS Dimensions A L S2 mm. 6.5 40.5 8 in. 0,26 1,59 0,31 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.00.ZZZ.PA060 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables 18000 PTFE Brown CCX.95.RG1.80BU36M PTFE Brown CCX.95.RG1.95AU37B PFA White LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
PCA.00.250.CTLK42Z 价格&库存
很抱歉,暂时无法提供与“PCA.00.250.CTLK42Z”相匹配的价格&库存,您可以联系我们找货
