PSA.0S.250.CTLC27
PSA.0S.250.CTLC27
    LEMO(雷莫)
    PSA.0S.250.CTLC27
PSA.0S.250.CTLC27 数据手册
PSA.0S.250.CTLC27 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 0S Termination type Female solder Coaxial IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 2.30 - 3.20 mm Status active Alternative part PSA.0S.250.CTLC32 Matching parts FFA.0S.250.CTAC27 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model PSA*: Fixed receptacle, nut fixing, cable collet Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 8.21 g Performance Configuration 0S.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 6 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 1 mm (0.039in) Vtest: 3000 V (AC), 4200 V (DC) Impedance: 50 Ohm VSWR: 1.02 + 0.25 * f/GHz Cable type: RG 178 B/U, RG 196 A/U, RG 188 A/U, RG 316 B/U, RG 174 A/U, HF-2114, RG 122 /U LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A B C E L M S1 S2 S3 e mm. 10 12.5 4.2 7 33.5 1.2 8.2 6.5 11 M9x0.6 in. 0,39 0,49 0,17 0,28 1,32 0,05 0,32 0,26 0,43 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.0S.ZZZ.PA065 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables 17420 PVC Black 17450 COPOLYMER Black 18700 PTFE White 18800 PTFE White 31600 PTFE Brown CCX.50.RG0.58AU14B FEP White CCX.50.RG1.74-U25N PVC Black CCX.50.RG1.74AU28N PVC Black CCX.50.RG1.74AU28N PVC Black CCX.50.RG1.74U25N PVC Black CCX.50.RG1.88AU24B TFE White CCX.50.RG1.88AU26B PFA White CCX.50.RG1.88AU26B PTFE White CCX.50.RG3.16BU26M FEP Brown CCX.50.RG3.16U28M PTFE Brown CCX.75.RG1.79BU26M FEP Brown CCX.75.RG1.87AU26B PFA White CCX.75.RG1.87AU27B PTFE White LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
PSA.0S.250.CTLC27 价格&库存
很抱歉,暂时无法提供与“PSA.0S.250.CTLC27”相匹配的价格&库存,您可以联系我们找货
