FAA.0E.250.CTA
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
0E
Termination type
Male solder Coaxial
IP rating
68 when mated
AWG wire size
0.00 - 0.00
Cable Ø
0.00 - 0.00 mm
Status
active
Matching parts
PCA.0E.250.CLLC30D
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FAA*: Fixed plug, non-latching, nut fixing
Keying
Circular, male
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
14.79 g
Performance
Configuration
0E.250 : 1 Coax (50 Ohm)
Insulator
T: PTFE
Rated Current
6 Amps
Specifications
Contact Type: Coaxial 50 Ohm (Solder)
Contact Dia.: 0.9 mm (0.035in)
Bucket Dia.: 1 mm (0.039in)
Vtest: 3000 V (AC), 4200 V (DC)
Impedance: 50 Ohm
VSWR: 1.02 + 0.25 * f/GHz
Cable type: RG 178 B/U, RG 196 A/U, RG 188 A/U, RG 316 B/U, RG 174 A/U, HF-2114, RG 122 /U
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/4
Others
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +200°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
B
E
L
M
S1
S3
e
mm.
18
19.5
3.5
19.5
13
12.5
17
M14x1.0
in.
0,71
0,77
0,14
0,77
0,51
0,49
0,67
RECOMMENDED BY LEMO
Tools
Caps:
BFA.0E.100.NAS
2/4
Cables
158480
PUR
Black
158490
PVC
Black
159580
PVC
Black
17420
PVC
Black
17450
COPOLYMER
Black
178190
PTFE
Brown
18000
PTFE
Brown
18700
PTFE
White
18800
PTFE
White
196270
PTFE
White
31600
PTFE
Brown
62000
PVC
Black
CCX.50.030.083.180B
White
CCX.50.080.297538N
PVC
Black
CCX.50.088.292495N
PVC
Black
CCX.50.RG0.58AU14B
FEP
White
CCX.50.RG0.58AU61J
PVC
Yellow
CCX.50.RG1.74-U25N
PVC
Black
CCX.50.RG1.74AU28N
PVC
Black
CCX.50.RG1.74AU28N
PVC
Black
CCX.50.RG1.74U25N
PVC
Black
CCX.50.RG1.78BU18M
FEP
Brown
CCX.50.RG1.78BU18M
PTFE
Brown
CCX.50.RG1.88AU24B
TFE
White
CCX.50.RG1.88AU26B
PFA
White
CCX.50.RG1.88AU26B
PTFE
White
CCX.50.RG1.96AU19B
PTFE
White
CCX.50.RG1.96AU20B
PFA
White
CCX.50.RG3.16BU26M
FEP
Brown
CCX.50.RG3.16U28M
PTFE
Brown
CCX.50.RG5.8CU50N
PVC
Black
CCX.75.040.195327G
PVC
Grey
CCX.75.RG0.59BU62N
PVC
Black
CCX.75.RG1.79BU26M
FEP
Brown
CCX.75.RG1.87AU26B
PFA
White
3/4
CCX.75.RG1.87AU27B
CCX.93.RG0.62AU62N
PTFE
PVC
White
Black
CCX.95.RG1.80BU36M
PTFE
Brown
CCX.95.RG1.95AU37B
PFA
White
4/4
很抱歉,暂时无法提供与“FAA.0E.250.CTA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+275.125351+35.59167
- 10+233.8106210+30.24698
- 25+219.1698125+28.35296
- 50+208.7122750+27.00012
- 100+198.75820100+25.71241
- 250+186.32928250+24.10454
