1204-6000
1204-6000
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPJACKSTR50OHMSOLDER
1204-6000 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV DATE APPROVED - REL. NRN 34431 11/29/07 STW A DCN 37782 09/10 PJS .093 2.36 PANEL THICKNESS .220 5.59 .150 3.81 SMP FEMALE PER MIL-STD-348 SPACER .135 3.43 MAX. MATERIALS: BODIES, CONTACT & SPRING CLIP: SLEEVE, & INSERT: BUSHING: SPRING: INSULATOR: DIELECTRIC SPACER: FINISHES: BODIES, CONTACT & SPRING CLIP: BUSHING: SLEEVE, INSERT & SPRING: ELECTRICAL: IMPEDANCE: FREQ. RANGE: VSWR: INSERTION LOSS: D.W.V.: INSULATION RES.: .290 7.37 BERYLLIUM COPPER PER ASTM B196 STAINLESS STEEL PER AMS 5640, ALLOY No. UNS S30300, TYPE 1 BRASS PER ASTM B16, ALLOY UNS No. C36000 STAINLESS STEEL PER ASTM A313 PTFE PER ASTM D1710 TORLON 4203 .293 7.44 .268±.001 6.81±0.03 RP .484 12.29 .093±.002 2.36±0.05 30° GOLD PER ASTM B488, TYPE II GRADE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1 NICKEL PER AMS-QQ-N-290, CLASS 2 PASSIVATED PER AMS 2700 .272±.001 6.91±0.03 50 OHMS DC TO 18.0 GHZ 1.20 MAX. 0.25 dB MAX. 500 VRMS 5,000 MEGOHMS MINIMUM FLOAT: AXIAL FLOAT: .040 INCH RADIAL FLOAT: .020 INCH SPRING FORCE: SPRING RATE: 39 LBS/INCH NOM. PRE-LOAD: 0.81 LBS NOM. .035" COMPRESSION: 2.15 LBS NOM. .125" COMPRESSION: 5.6 LBS NOM. .283±.002 7.19±0.05 RECOMMENDED MOUNTING HOLE MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: JMC 12/03/07 CHECKED: APPROVED: STW 12/04/07 STW 12/04/07 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMP FEMALE, FLOAT MOUNT T-FLEX 405, .093" PANEL THK. SIZE CAGE CODE DWG. NO. B 95077 SCALE: 8:1 1204-6000 SHEET 1 OF 1
1204-6000 价格&库存
很抱歉,暂时无法提供与“1204-6000”相匹配的价格&库存,您可以联系我们找货
  • 1+681.905141+88.12404
  • 10+579.6001310+74.90295
  • 25+557.7919525+72.08463
