PCA.00.650.CLLC27Z
PCA.00.650.CLLC27Z
    LEMO(雷莫)
    PCA.00.650.CLLC27Z
PCA.00.650.CLLC27Z 数据手册
PCA.00.650.CLLC27Z www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 00 Termination type Female solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 2.30 - 2.70 mm Status active Matching parts FFC.00.650.CLAC27Z Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model PCA*: Free receptacle with cable collet Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 4.63 g Performance Configuration 00.650 : 1 Triax (50 Ohm) Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 3 Amps Specifications Contact Type: Triaxial 50 Ohm (Solder) Contact Dia.: 0.5 mm (0.02"in) Vtest: 1200 V (AC), 1700 V (DC) Impedance: 50 Ohm VSWR: 1.1 + 0.11 * f/GHz LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Others Endurance (Shell): 5000 mating cycles Salt Spray Corrosion: >1000 hr DRAWINGS Dimensions A L S2 mm. 6.5 32.5 6 in. 0,26 1,28 0,24 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.00.ZZZ.PA060 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
PCA.00.650.CLLC27Z 价格&库存
很抱歉,暂时无法提供与“PCA.00.650.CLLC27Z”相匹配的价格&库存,您可以联系我们找货
