GRF7-J-P-06-GF-ST-TH1-E
    SAMTEC(申泰)
    插件
GRF7-J-P-06-GF-ST-TH1-E 数据手册
DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] REVISION J C SERIES GRF1-: GRF 50 OHM CONNECTORS GRF7-: GRF 75 OHM CONNECTORS (SEE SHT 1, TABLE 1) (No OF POS x 5.00[.197] REF -A- (No OF POS -1) x 5.00[.197] C DO NOT SCALE FROM THIS PRINT 5.00 .197 REF (TYP) GRFX-J-P-XX-XX-XX-XXX-X * NOT RELEASED FOR PRODUCTION "A" -B- INSERT OPTIONS -E: #1-64 THRU HOLE THREADED INSERT (SEE FIG 2, SHT 2) GENDER -J: JACK TERMINATION -TH1: THRU HOLE * -SM1: SURFACE MOUNT * -MT1: MIXED TECHNOLOGY (SEE SHT 2, TABLE 3) PCB -P: PCB MOUNT 5.00 .197 REF ORIENTATION -ST: STRAIGHT No OF POSITIONS -02, -04, -06, -08 PLATING -E: 30µ" GOLD CENTER CONTACT, 5µ" GOLD OUTER CONTACT. (FOR GRF1 ONLY) -HF: 30µ" GOLD CENTER CONTACT, 3µ" GOLD OUTER CONTACT. (FOR GRF7 ONLY) -GF: 10µ" GOLD CENTER CONTACT, 3µ" GOLD OUTER CONTACT. (SEE SHT 2, TABLE 2) (FOR GRF7 ONLY) 3.50 .138 REF (TYP) "C" REF (SOCKET) "A" C +0.10 XXX-GRFX-J-P-XX-ST-XXX +.004 2.80 - 0.15 .110 - .006 (NO OF POS PLCS) GRF1-XX-XX-XXX 4.60 .181 REF 2.00 .079 REF 1.80 .071 REF 0.50 .020 SQ REF (TYP) ((No OF POS -1) x 5.00[.197]) +"A" "A" REF (TYP) GRF1-J-P-XX-ST-TH1 0.15 .006 REF (TYP) "D" REF 2.80 .110 REF (TYP) "B" REF (TYP) 0.30 A B C 2.75 .108 REF (TYP) *GRF7-J-P-XX-ST-MT1 *GRF7-J-P-XX-ST-SM1 5.00 .197 REF (TYP) (No OF POS -1) x 5.00[.197] FIG 1 GRF1-J-P-04-XX-ST-TH1 SHOWN 0.15 .006 0.05 .002 REF (TYP) DETAIL 'B' SCALE 8 : 1 'B' SCALE 3 : 1 * UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS. TOLERANCES ARE: * DECIMALS NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM PUSHOUT FORCE: 2.22N[.5 LB]. 3. NOTE DELETED. 2.65 .104 REF (TYP) SCALE 3 : 1 SCALE 3 : 1 SECTION "A"-"A" SCALE 6 : 1 "A" REF (TYP) SUB-GRF7-J-P-XX-ST-TH1 CRITICAL DIMENSION INSPECTION INSTRUCTION TABLE ASSEMBLY OPERATION IN-PROCESS INSPECTION FILL C1, C2, C3, C6 F:\DWG\MISC\MKTG\GRFX-J-P-XX-XX-XX-XXX-X-MKT.SLDDRW X.X: 0.3 X.XX: 0.13 X.XXX: 0.050 MATERIAL: ANGLES 5 PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: L.C.P. COLOR: BLACK SHELL: BRASS SOCKET: BeCu INSULATOR: PTFE SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: GANGED RF JACK CONNECTOR DWG. NO. GRFX-J-P-XX-XX-XX-XXX-X BY: CHAD F 9/3/2004 SHEET 1 OF 3 REVISION J No OF POS x 5.00[.197] + 12.20[.480] REF -A- No OF POS x 5.00[.197] + 7.20[.283] C "A" -B- #1-64 UNC-2B 5.00 .197 REF PACKAGING VIEW -SM1 USE: PT-01-24-01-25 & TP-09 "A" 3.50 .14 REF (2 PLCS) PACKAGING VIEW -TH1 & MT1 USE: PT-ASP003 & TP-09 C +0.10 2.45 - 0.15 GRF1-XX-XX-XXX-E +.004 .096 - .006 (2 PLCS) 2.80 .110 REF (2 PLCS) WT-21-01 (2 PLCS) "B" REF (TYP) 0.30 A B C (No OF POS x 5.00[.197]) + 9.74[.383] 2.54 .100 REF (TYP) FIG 2 GRF1-J-P-04-XX-ST-TH1-E SHOWN (SAME AS FIG 1, UNLESS OTHERWISE STATED) CRITICAL DIMENSION INSPECTION INSTRUCTION TABLE (FOR -E) * * * * ASSEMBLY OPERATION IN-PROCESS INSPECTION FILL CONNECTOR & ASSEMBLY THREADED INSERT C1, C2, C3, C4, C5, C7 PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING * * SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\GRFX-J-P-XX-XX-XX-XXX-X-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: GANGED RF JACK CONNECTOR DWG. NO. GRFX-J-P-XX-XX-XX-XXX-X BY: CHAD F 9/3/2004 SHEET 2 OF 3 REVISION J *GRF7-J-P-04-XX-ST-SM1 SHOWN *GRF7-J-P-04-XX-ST-MT1 SHOWN GRF7-J-P-04-XX-ST-TH1 SHOWN GRF1-J-P-04-XX-ST-TH1 SHOWN GRF7-J-P-04-XX-ST-TH1-E SHOWN GRF1-J-P-04-XX-ST-TH1-E SHOWN PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\GRFX-J-P-XX-XX-XX-XXX-X-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: DWG. NO. GANGED RF JACK CONNECTOR GRFX-J-P-XX-XX-XX-XXX-X BY: CHAD F 9/3/2004 SHEET 3 OF 3
GRF7-J-P-06-GF-ST-TH1-E 价格&库存
很抱歉,暂时无法提供与“GRF7-J-P-06-GF-ST-TH1-E”相匹配的价格&库存,您可以联系我们找货
