ROHS COMPLIANT
REVISION HISTORY
DESCRIPTION
REV
CUI BASIC
DCN 40883
DATE
APPROVED
10/14
STW
PRODUCT DATA DRAWING
.827 21
.933 23.7
MATERIAL:
BODY,
CONTACT &
COUPLING NUT:
BRASS
INSULATOR:
PTFE
FINISH:
BODY &
COUPLING NUT:
NICKEL
CONTACT:
GOLD
PERFORMANCE:
OPERATING TEMP.:
MATERIAL:
FINISH:
SEE NOTES
SEE NOTES
SURFACE AREA:
-55 C TO +125 C
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
.030
.010
.005
ANGULAR: X
X X'
1 0'
15'
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
SV Microwave, Inc.
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
MAL 10/23/14
CHECKED:
APPROVED:
STW 10/23/14
STW 10/23/14
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
FOR
N STRAIGHT PLUG
.085 CABLE (SOLDER)
SIZE CAGE CODE DWG. NO.
B
95077
SCALE: 3:1
5011-00034
SHEET 1 OF 1
很抱歉,暂时无法提供与“5011-00034”相匹配的价格&库存,您可以联系我们找货
