9311-60035
9311-60035
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPPLUGSTR50OHMEDGEMNT
9311-60035 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION DATE APPROVED - DCN 38469 08/11 STW A NRN 40649 05/16 STW B DCN 49690 03/20 DMS REV 2X .165 4.19 RP .140 3.56 .290 7.37 .090 2.29 .230 5.84 .180 4.57 5X .090 2.29 2X .065 1.65 2X .015 0.38 2X .160 4.06 .360±.010 9.14±0.25 .490 12.45 SV PART NUMBER COUPLING STYLE 9311-60033 SMOOTH BORE 9311-60034 LIMITED DETENT 9311-60035 FULL DETENT .192 4.88 MATERIAL: BODY & SHROUDS: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACTS: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATORS: 3X .104 2.63 3X .0075±.0010 0.19±0.03 3X .015 0.38 2X .200±.002 5.08±0.05 2X .100 2.54 PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B .0725±.0010 1.84±0.03 .400±.004 10.16±0.10 FINISH: BODY, SHROUDS & CONTACTS: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. MATERIAL: FINISH: PERFORMANCE: IMPEDANCE: FREQ. RANGE: NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com SEE NOTES SEE NOTES SURFACE AREA: 50 OHMS DC TO 26.5 GHz. N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 .030 .010 .005 ANGULAR: X X X' 1 0' 15' INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: FSG 08/16/11 CHECKED: APPROVED: STW 08/16/11 STW 08/16/11 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SIZE B SMP FD MALE 2-PORT PCB EDGE MOUNT DWG. NO. SCALE: 8:1 9311-60033-60035 SHEET 1 OF 2 ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION DATE APPROVED - DCN 38469 08/11 STW A NRN 40649 05/16 STW B DCN 49690 03/20 DMS REV .140 3.56 2X ZERO CORNER BREAK: ENSURE ZERO TO NO RADIUS SO CONNECTOR SITS FLUSH TO FACE .406 MIN 10.31 MIN ENSURE EDGE OF BOARD DOES NOT INTERFERE WITH MATING CONNECTOR MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 .030 .010 .005 ANGULAR: X X X' 1 0' 15' INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: FSG 08/16/11 CHECKED: APPROVED: STW 08/16/11 STW 08/16/11 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMP FD MALE 2PORT PCB EDGE MOUNT SIZE CAGE CODE DWG. NO. 9311-60035 B 95077 SCALE: 16:1 SHEET 2 OF 2
9311-60035
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入、输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为4x4mm。
9311-60035 价格&库存
很抱歉,暂时无法提供与“9311-60035”相匹配的价格&库存,您可以联系我们找货
  • 25+1226.9523425+158.51268
