PCA.1S.250.CTLC62
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
1S
Termination type
Female solder Coaxial
IP rating
50
AWG wire size
0.00 - 0.00
Cable Ø
5.20 - 6.20 mm
Status
active
Matching parts
FFA.1S.250.CTAC62
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
PCA*: Free receptacle, cable collet
Keying
Circular, female
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
20.36 g
Performance
Configuration
1S.250 : 1 Coax (50 Ohm)
Insulator
T: PTFE
Rated Current
12 Amps
Specifications
Contact Type: Coaxial 50 Ohm (Solder)
Contact Dia.: 1.6 mm (0.063in)
Bucket Dia.: 1.4 mm (0.055in)
Vtest: 3000 V (AC), 4200 V (DC)
Impedance: 50 Ohm
VSWR: 1.01 + 0.23 * f/GHz
Cable type: RG 178 B/U, RG 196 A/U, RG 188 A/U, RG 316 B/U, RG 174 A/U, HF-2114, RG 122 /U
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Others
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +250°C
Humidity (max): 144 hr
DRAWINGS
Dimensions
A
C
L
S2
mm.
11.9
6.2
40.5
8.5
in.
0,47
0,24
1,59
0,33
RECOMMENDED BY LEMO
Tools
Spanner wrench:
DCD.1S.ZZZ.PA085
2/3
Cables
159580
PVC
Black
62000
PVC
Black
CCX.50.080.297538N
PVC
Black
CCX.50.RG0.58AU61J
PVC
Yellow
CCX.75.RG0.59BU62N
PVC
Black
CCX.93.RG0.62AU62N
PVC
Black
3/3
很抱歉,暂时无法提供与“PCA.1S.250.CTLC62”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+252.5424810+32.67023
