PCA.0A.250.NTLC29
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
0A
Termination type
Female solder
IP rating
50
AWG wire size
0.00 - 0.00
Cable Ø
2.50 - 2.80 mm
Status
active
Matching parts
FFA.0A.250.NTAC29
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
PCA*: Straight receptacle with cable collet
Keying
Housing Material
Brass (nickel plated [SAE AMS QQ N 290]) shell, collet nut, latch sleeve and mid pieces
Weight
8.88 g
Performance
Configuration
0A.250 : 1 Coax (50 Ohm)
Insulator
Rated Current
Specifications
Contact Type: Coaxial 50 Ohm (Solder)
Others
Endurance (Shell): 5000 mating cycles
Salt Spray Corrosion: >144 hr
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
DRAWINGS
Dimensions
A
B
L
S1
S2
S3
mm.
9
10
35
8
8.5
9
in.
0,35
0,39
1,38
0,31
0,33
0,35
RECOMMENDED BY LEMO
Tools
Cables
17420
PVC
Black
17450
COPOLYMER
Black
18700
PTFE
White
18800
PTFE
White
31600
PTFE
Brown
CCX.50.RG1.74-U25N
PVC
Black
CCX.50.RG1.74AU28N
PVC
Black
CCX.50.RG1.74AU28N
PVC
Black
CCX.50.RG1.74U25N
PVC
Black
CCX.50.RG1.88AU26B
PFA
White
2/3
CCX.50.RG1.88AU26B
PTFE
White
CCX.50.RG3.16BU26M
FEP
Brown
CCX.50.RG3.16U28M
PTFE
Brown
CCX.75.RG1.79BU26M
FEP
Brown
CCX.75.RG1.87AU26B
PFA
White
CCX.75.RG1.87AU27B
PTFE
White
3/3
很抱歉,暂时无法提供与“PCA.0A.250.NTLC29”相匹配的价格&库存,您可以联系我们找货
