138-4308-407
138-4308-407
    CINCH
138-4308-407 数据手册
Type N Straight Plug One Piece Style for Semi-Rigid Cable 1. Identify connector and tools. (4 piece parts) 2. Strip cable jacket and dielectric to dimension shown. Do not nick center conductor. 3. Bevel end of cable center conductor per appropriate dimensional profile. 4. Clean all debris from prepared cable and insert cable into connector assembly, making sure cable jacket bottoms out against internal shoulder of connector assembly and center conductor engages with internal captivated plug contact. 5. Insert location fixture into connector assembly and clamp cable in vise. Tighten stop screw until light pressure is applied between connector assembly and cable jacket. 6. Solder connector body to cable jacket, using a minimum amount of solder for a full fillet joint. Allow assembly to cool before removing connector from vise. Cable Group Part No. “A” “B” RG-405, .086 Semi-Rigid 138-4693-011 .085 (2.16) .014 (0.36) RG-402, .141 Semi-Rigid 138-4694-011 .085 (2.16) .022 (0.56) RG-401, .250 Semi-Rigid 138-4696-011 .150 (3.81) .045 (1.14) Assembly Location Fixture 140-0000-983 140-0000-983 140-0000-983 Cable Vise 140-0000-962 140-0000-962 140-0000-962 Clamp Inserts 140-0000-964 140-0000-965 140-0000-986 Stop Screw 140-0000-981 140-0000-981 140-0000-981 267 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
138-4308-407 价格&库存
很抱歉,暂时无法提供与“138-4308-407”相匹配的价格&库存,您可以联系我们找货
  • 50+314.6585950+40.90460
