SF3321-60003
SF3321-60003
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONN1.85MMJKSTR50OHMCOMPRES
SF3321-60003 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV - NRN 42113 DATE APPROVED 03/18 STW .450 11.42 .065 1.65 .625 15.88 2X .103 2.62 .171 4.34 .481 12.22 ACCEPTS Ø.009 PIN X .060 MAX LONG M7X.75-6g MATERIAL: BODY & INSERT: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: ULTEM .004 0.10 .111 2.82 .222 5.64 FINISH: BODY & INSERT: CONTACT: PASSIVATED PER AMS-2700. GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: FREQ. RANGE: VSWR: INSERTION LOSS: MATERIAL: FINISH: 50 OHMS DC TO 65.0 GHz 1.33:1 DC TO 65.0 GHz .05 X SQRT(F(F IN GHz)) SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: FSG 03/02/12 CHECKED: APPROVED: STW 03/02/12 STW 03/02/12 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: 1.85MM JACK 2 HOLE FLANGE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 4:1 SF3321-60003 SHEET 1 OF 1
SF3321-60003 价格&库存
很抱歉,暂时无法提供与“SF3321-60003”相匹配的价格&库存,您可以联系我们找货
SF3321-60003
  • 1+838.882851+108.66467
  • 10+713.0717610+92.36773
  • 25+668.4542825+86.58821
  • 50+636.5827150+82.45973
  • 100+606.24117100+78.52944
库存:2
