ROHS COMPLIANT
PRODUCT DATA DRAWING
C
DCN 39509
DATE
APPROVED
11/12
STW
.252 6.40
SMPS MALE INTERFACE
SMOOTH BORE
.104 2.64
REVISION HISTORY
DESCRIPTION
REV
.090 2.29
.077 1.96
.158 4.01
TO CABLE STOP
.049 1.24
RP
MATERIAL:
BODY &
CONTACT:
INSULATOR:
FINISH:
BODY &
CONTACT:
BERYLLIUM COPPER PER ASTM B196,
ALLOY No. UNS C17300, TD04
PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B
GOLD PER ASTM B 488, TYPE II,
CODE C, CLASS 1.27; OVER NICKEL
PER AMS-QQ-N-290, CLASS 1, .00005" MIN.
PERFORMANCE:
IMPEDANCE:
VSWR:
50 OHMS
1.20:1 DC TO 40.0 GHz TYPICAL
1.30:1 TO 65.0 GHz TYPICAL
INSERTION LOSS: .12 X SQRT(F(F IN GHz))
DWV:
250 VRMS
OPERATING TEMP.: -55 C TO +165 C
ENGAGEMENT:
DISENGAGEMENT:
1.6 LBS TYPICAL
0.50 LBS TYPICAL
MATERIAL:
FINISH:
SEE NOTES
SEE NOTES
SURFACE AREA:
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
ANGULAR: X
X X'
1 0'
15'
.030
.010
.005
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
SV Microwave, Inc.
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
JMC 08/12/09
CHECKED:
APPROVED:
JM 02/06/06
JM 02/06/06
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
SMPS MALE SMOOTH BORE
FOR .047 SEMI-RIGID CABLE
SIZE CAGE CODE DWG. NO.
B
95077
SCALE: 20:1
3811-40002
SHEET 1 OF 1
很抱歉,暂时无法提供与“3811-40002”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+712.091661+92.39058
