1711-60008
1711-60008
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNBMAPLUGSTR50OHMSOLDER
1711-60008 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING - DCN 37299 DATE APPROVED 01/10 PJS .568 14.43 .260 6.60 .065 1.65 .200 5.08 .120 3.05 .250 6.35 .481 12.22 .625 15.88 MATERIAL: BODY: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B O-RING: FLUOROCARBON RUBBER PER MIL-R-83248B TYPE 1, CLASS 1 .065 1.65 2X .102 2.59 .390 9.91 FINISH: BODY & CONTACT: GOLD PER ASTM B488, TYPE II, CODE C, CLASS .76, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: FREQ. RANGE: DWV: INSUL. RES.: 50 OHMS DC TO 22.0 GHz 1000 VRMS 5,000 MEGOHMS MIN. MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: FED 01/13/10 CHECKED: APPROVED: PJS 01/13/10 PJS 01/13/10 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: BMA PLUG, FLANGE MOUNT FOR .085 S.R. CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 5:1 1711-60008 SHEET 1 OF 1
1711-60008 价格&库存
很抱歉,暂时无法提供与“1711-60008”相匹配的价格&库存,您可以联系我们找货
