EPL.0S.250.CTN
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
0S
Termination type
Female print PCB Coaxial
IP rating
50
AWG wire size
0.00 - 0.00
PCB Altium Pattern
Cable Ø
0.00 - 0.00 mm
PCB KiCad Pattern
Status
active
Catalog
Matching parts
FFA.0S.250.CLAC17
Download
Request a quote
PCB Eagle Pattern
TECHNICAL DETAILS
Mechanics
Shell Style/Model
EPL*: Elbow receptacle for printed circuit
Keying
Circular, female
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
6.17 g
Performance
Configuration
0S.250 : 1 Coax (50 Ohm)
Insulator
T: PTFE
Rated Current
6 Amps
Specifications
Contact Type: Coaxial 50 Ohm (PCB)
Contact Dia.: 0.9 mm (0.04in)
Bucket Dia.: 1 mm (0.04in)
Test Voltage(kV rms) 1.2
Cable type: RG 178 B/U, RG 196 A/U, RG 188 A/U, RG 316 B/U, RG 174 A/U, HF-2114, RG 122 /U
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
D
H
I
K
L
N
mm.
8.8
16
12
9
7.7
22.7
9
in.
0,35
0,63
0,47
0,35
0,30
0,89
0,35
RECOMMENDED BY LEMO
Tools
Spanner wrench:
Socket for torque wrench DCM.0S.M09.4
2/3
3/3
很抱歉,暂时无法提供与“EPL.0S.250.CTN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+257.9991910+33.37614
