EPL.0S.250.CLN
EPL.0S.250.CLN
    LEMO(雷莫)
    插件
    EPL.0S.250.CLN
EPL.0S.250.CLN 数据手册
EPL.0S.250.CLN www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 0S Termination type Female print PCB Coaxial IP rating 50 AWG wire size 0.00 - 0.00 PCB Altium Pattern Cable Ø 0.00 - 0.00 mm PCB KiCad Pattern Status active Catalog Matching parts FFA.0S.250.CLAC17 Download Request a quote PCB Eagle Pattern TECHNICAL DETAILS Mechanics Shell Style/Model EPL*: Elbow receptacle for printed circuit Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 6.03 g Performance Configuration 0S.250 : 1 Coax (50 Ohm) Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 6 Amps Specifications Contact Type: Coaxial 50 Ohm (PCB) Contact Dia.: 0.9 mm (0.04in) Bucket Dia.: 1 mm (0.04in) Test Voltage(kV rms) 1.2 Cable type: RG 178 B/U, RG 196 A/U, RG 188 A/U, RG 316 B/U, RG 174 A/U, HF-2114, RG 122 /U Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A D H I K L N mm. 8.8 16 12 9 7.7 22.7 9 in. 0,35 0,63 0,47 0,35 0,30 0,89 0,35 RECOMMENDED BY LEMO Tools Spanner wrench: Socket for torque wrench DCM.0S.M09.4 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
EPL.0S.250.CLN 价格&库存
很抱歉,暂时无法提供与“EPL.0S.250.CLN”相匹配的价格&库存,您可以联系我们找货
