SF3202-6001
SF3202-6001
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPMPLUGSTR50OHMSOLDER
SF3202-6001 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING DATE - REL. NRN 33610 02/15/06 1 REVISED 07/13/06 APPROVED STW (.750 19.05 ) .435 11.05 .168 4.27 .151 3.84 .182 4.62 INSTALLED .025 0.64 .122 3.10 .155±.002 3.94±0.05 .088±.001 2.24±0.03 MATERIAL: BODY & INSERT: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 SPRING: STAINLESS STEEL PER ASTM A313, TYPE 631 ALLOY UNS S17700 CONTACT & RETAINING RING: INSULATOR: .082 2.08 A .164±.001 4.17±0.03 .160±.002 4.06±0.05 BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B FINISH: BODY, INSERT & SPRING: PASSIVATED PER AMS-2700, TYPE 2 CONTACT: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27; OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. RETAINING RING: NICKEL PER AMS-QQ-N-290, CLASS 1, GRASE G. .167±.001 4.24±0.03 .1775±.0025 4.51±0.06 PERFORMANCE: IMPEDANCE: FREQ. RANGE: DWV: OPERATING TEMP.: ENGAGEMENT/ DISENGAGEMENT: 50 OHMS DC TO 65.0 GHz 325 VRMS -55 C TO +125 C 2.5 LBS MAX. ENGAGEMENT 1.5 LBS MIN. DISENGAGEMENT MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: JMC 02/15/05 CHECKED: APPROVED: STW 02/15/06 STW 02/15/06 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMPM MALE TO .047 S/R CABLE CATCHERS MITT INTERFACE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 8:1 SF3202-6001 SHEET 1 OF 1
SF3202-6001 价格&库存
很抱歉,暂时无法提供与“SF3202-6001”相匹配的价格&库存,您可以联系我们找货
