FFA.0S.650.CTLC37Z
www.lemo.com
SUMMARY
# Wires
Triax
1
Image is for illustrative purpose only
Series
0S
Termination type
Female solder
IP rating
50
AWG wire size
0.00 - 0.00
Cable Ø
3.30 - 3.70 mm
Status
active
Matching parts
ERA.0S.650.CTA
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FFA*: Straight plug, cable collet and nut for fitting a bend relief
Keying
Circular, female
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Variant
Z : Nut for fitting a bend relief
Weight
8.47 g
Performance
Configuration
0S.650 : 1 Triax (50 Ohm)
Insulator
T: PTFE
Rated Current
6 Amps
Specifications
Contact Type: Triaxial 50 Ohm (Solder)
Contact Dia.: 0.9 mm (0.035"in)
Vtest: 1200 V (AC), 1700 V (DC)
Impedance: 50 Ohm
VSWR: 1.03 + 0.34 * f/GHz
Cable type: RGT 178, RGT 174
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Others
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +250°C
Humidity (max): 144 hr
DRAWINGS
Dimensions
A
L
M
S2
mm.
9
34.5
24.5
7
in.
0,35
1,36
0,96
0,28
RECOMMENDED BY LEMO
Tools
Spanner wrench:
DCD.0S.ZZZ.PA065
2/3
3/3
很抱歉,暂时无法提供与“FFA.0S.650.CTLC37Z”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+266.5035710+34.47631
