SF1711-60013
SF1711-60013
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNBMARCPTSTR50OHMCOMPRESS
SF1711-60013 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING .375 9.53 REVISION HISTORY DESCRIPTION DATE APPROVED 01 PRELIMINARY 08/11 FED - REL. NRN 41940 11/27/17 STW REV .014±.006 0.36±0.15 .260 6.60 .065 1.65 .250 6.35 .481 12.22 ACCEPTS .018 .001 CONTACT X .110 MIN DEEP O-RING EMI GASKET 2X MATERIAL: .102 2.59 THRU .625 15.88 BODY: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 OR ASTM A582, TYPE 303, CONDITION A. CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04. INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B O-RING: FLUOROSILICONE RUBBER PER SAE-AMS-R-25988, CLASS 1, TYPE I. EMI GASKET: CONDUCTIVE SILVER/SILICONE ELASTOMER PER MIL-DTL-83528. FINISH: BODY: PASSIVATED PER AMS 2700. CONTACT: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. MATERIAL: PERFORMANCE: IMPEDANCE: FREQ. RANGE: VSWR: INSERTION LOSS: FINISH: 50 OHMS DC TO 18.0 GHz 1.04+.006*F (F IN GHz) DC TO 18.0 GHz .03 X SQRT(F(F IN GHz)) SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: FED 08/19/11 CHECKED: APPROVED: JMC 11/22/17 STW 11/27/17 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 BMA 2-HOLE FLANGE MOUNT PLUG RECEPTACLE ACCEPTS Ø.018±.001 PIN TITLE: SIZE CAGE CODE DWG. NO. B 95077 SCALE: 6:1 SF1711-60013 SHEET 1 OF 1
SF1711-60013 价格&库存
很抱歉,暂时无法提供与“SF1711-60013”相匹配的价格&库存,您可以联系我们找货
