ROHS COMPLIANT
REVISION HISTORY
DESCRIPTION
REV
PRODUCT DATA DRAWING
NRN 34840
DATE
APPROVED
07/08
STW
( .302 7.67 )
.080 2.03
.156 3.96
.146 3.71 )
.090±.001 2.29±0.03
2X
.178 4.52
.093±.002 2.36±0.05
FOR .093 PANEL
MATERIAL:
BODY:
SLEEVE,
CONTACT &
RETAINING RING:
INSULATOR:
30°
STAINLESS STEEL PER AMS-5640, UNS 30300 (TYPE 1)
BERYLLIUM COPPER PER ASTM B196,
ALLOY No. UNS C17300, TD04
.160±.001 4.06±0.03
.1715±.0015 4.36±0.04
PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B
FINISH:
BODY:
SLEEVE,
CONTACT &
RETAINING RING:
PASSIVATED PER AMS-QQ-P-35, TYPE II
GOLD PER ASTM B 488, TYPE II,
CODE C, CLASS 1.27; OVER NICKEL
PER AMS-QQ-N-290, CLASS 1, .00005" MIN.
RECOMMENDED PANEL HOLE
PERFORMANCE:
MATERIAL:
IMPEDANCE:
FREQ. RANGE:
VSWR:
50 OHMS
DC TO 40 GHz
1.25:1 DC TO 26.5 GHz
1.35:1 26.5 TO 40.0 GHz
DWV:
325 VRMS
OPERATING TEMP.:
-55 C TO +125 C
REMOVAL TOOL P/N 500-32-028
FINISH:
SEE NOTES
SEE NOTES
SURFACE AREA:
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
ANGULAR: X
X X'
1 0'
15'
.030
.010
.005
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
SV Microwave, Inc.
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
DAL 07/07/08
CHECKED:
APPROVED:
STW 07/07/08
STW 07/07/08
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
SMPM MALE FD SNAP-IN
FOR .093 PANEL FOR .086
S.R. CABLE
SIZE CAGE CODE DWG. NO.
B
95077
SCALE: 16:1
3211-40004
SHEET 1 OF 1
很抱歉,暂时无法提供与“3211-40004”相匹配的价格&库存,您可以联系我们找货
