3211-40005
3211-40005
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPMPLUGSTR50OHMSOLDER
3211-40005 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING - NRN 34841 DATE APPROVED 07/08 STW ( .302 7.67 ) .080 2.03 ( .156 3.96 .146 3.71 ) .090±.001 2.29±0.03 2X .178 4.52 .093±.002 2.36±0.05 FOR .093 PANEL MATERIAL: BODY: SLEEVE, CONTACT & RETAINING RING: INSULATOR: 30° STAINLESS STEEL PER AMS-5640, UNS 30300 (TYPE 1) BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 .160±.001 4.06±0.03 .1715±.0015 4.36±0.04 PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B FINISH: BODY: SLEEVE, CONTACT & RETAINING RING: PASSIVATED PER AMS-QQ-P-35, TYPE II GOLD PER ASTM B 488, TYPE II, CODE C, CLASS 1.27; OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. RECOMMENDED PANEL HOLE PERFORMANCE: MATERIAL: IMPEDANCE: FREQ. RANGE: VSWR: DWV: OPERATING TEMP.: 50 OHMS DC TO 40 GHz 1.25:1 DC TO 26.5 GHz 1.35:1 26.5 TO 40.0 GHz 325 VRMS -55 C TO +125 C REMOVAL TOOL P/N 500-32-028 FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: DAL 08/06/08 CHECKED: APPROVED: STW 08/06/08 STW 08/06/08 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMPM MALE SB SNAP-IN FOR .093 PANEL FOR .086 S.R. CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 16:1 3211-40005 SHEET 1 OF 1
3211-40005 价格&库存
很抱歉,暂时无法提供与“3211-40005”相匹配的价格&库存,您可以联系我们找货
  • 50+622.9995550+80.75261
