MMCX-BPJ-066(40)
MMCX-BPJ-066(40)
    HRS(广濑)
    CONN MMCX JACK
MMCX-BPJ-066(40) 数据手册
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MMCX Series Ultra-small Push-on Coaxial Connector Jan. 2022 ① MMCX Series/Ultra-small Push-on Coaxial Connector Features 1. Push- on System for Easy Attachment and Removal 2. Applicable Cable Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. RG Type High Frequency Coaxial Cable ・RG- 178B/ U (φ1. 8) ・RG- 316/ U (φ2. 59 Max. ) Extra- fine Fluororesin Cable ・Single Shielded Cable(φ1. 13,φ1. 37,φ1. 48) ・Double Shielded Cable(φ1. 32) Semi- flexible Cable ・External conductor diameter equivalent to 0. 085 inches ( With jacket finishing diameter is φ2. 5) ・External conductor diameter equivalent to 0. 047 inches ( With jacket finishing diameter is φ1. 44) 3. Double- ended Cable Assembly with Other Hirose Series Double- ended cable assembly available with H. FL, U. FL, SMA, and SMA( R) . 4. High Frequency Characteristics Guaranteed frequency : DC to 8GHz ( The guaranteed frequency of some parts is DC to 6GHz. ) 5. Two Types of Plugs Available In addition to the standard plug, a mating compatible outer conductor contact reinforced type is also available. 6. RoHS2 Compliant Application Examples Wireless LAN, GPS, POS, Measurement Instrument, Wiring Inside Transmission Equipment 2 MMCX Series/Ultra-small Push-on Coaxial Connector Product Specifications Characteristic Impedance 50 Ω Operating Temperature -55 to +85℃ Rated Frequency DC to 8GHz Operating Humidity Range 90% Max. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item Specification Condition Insulation Resistance 500 M Ω Min. Measured with 500V DC Withstanding Voltage No flashover or insulation breakdown 500V AC for 1 min. Contact Resistance Center : 10m Ω Max. Outer : 5m Ω Max. Measured at a maximum of 100mA (DC or 1000Hz) Retention Force of Female Contact 0.2 to 2N Measured with φ 0.37 pin gauge. Insertion Force : 15N Max., Extraction Force : 6 to 15N Standard Type Extraction Force : 6N Min. Outer Conductor Contact Reinforced Type [MMCX(AR)] 1.2 Max. DC to 6GHz 1.4 Max. 6 to 8GHz Vibration Resistance No electrical discontinuity for 1 μ s or more. No damaged, cracks or loose parts. Frequency of 10 to 500Hz, single amplitude of 0.75mm,acceleration of 98m/s2 for 12 cycles in each of the 3 axes direction. Thermal Shock No electrical discontinuity for 1 μ s or more. No damaged, cracks or loose parts. Acceleration of 735m/s2, for a duration of 6ms, sine half-wave waveform, 3 cycles in each of the 3 axes direction. Humidity Resistance No damaged, cracked or loose parts Insulation Resistance : 10M Ω Min. (High Humidity) Insulation Resistance : 500M Ω Min. (Dry) 96 hours at temperature of 40℃ and humidity of 95%. Temperature Cycle No damaged, cracked or loose parts. Temperature : -55℃ → +20 to +35℃ → +85℃ → +20 to +35℃ Time : 30 min. → 5 min. → 30 min. → 5 min. 5 cycles Mating Durability Contact Resistance Center : 20m Ω Max. Outer : 10m Ω Max. Mating/unmating : 500 mating cycles : Standard Type Mating/unmating : 100 mating cycles : Outer Conductor Contact Reinforced Type [MMCX(AR)] Salt Spray Satisfies the V.S.M.R. 5% salt water solution for 48 consecutive hours Total Insertion / Extraction Force (Plug) V.S.W.R.* (Note) Note : Refer to section on V.S.W.R. for details. * V. S. W. R. Measurement System The above V. S. W. R. standard values were measured using the measurement system shown below. Network Analyzer Test Set Test Port D.U.T Termination Test Port Cable Note 1 : The cable connector is measured attached to a double-ended cable assembly with an applicable 15cm cable. Note 2 : The board connector is measured while mounted to a 50 Ω board and attached to a dedicated adapter. 3 MMCX Series/Ultra-small Push-on Coaxial Connector ● V.S.W.R. V. S. W. R is 1. 2 Max. ( DC to 6GHz) or 1. 4 Max. ( 6 to 8GHz) excluding the products listed below. Item Part No. V.S.W.R. MMCX-R-SMT-8 1.2 Max. (DC to 8GHz) 1.2 Max. (DC to 4GHz) MMCX-LR-SMT(40) 1.3 Max. (4 to 6GHz) 1.4 Max. (6 to 8GHz) Receptacle MMCX-R-PC(40) 1.2 Max. (DC to 6GHz) 1.3 Max. (DC to 3GHz) MMCX-LR-PC-1(40) 1.5 Max. (3 to 6GHz) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MMCX(AR)-P-SF047 MMCX(AR)-P-SF085 1.3 Max. (DC to 3GHz) 1.4 Max. (3 to 8GHz) MMCX(AR)-LP-SF047 Plug / Jack MMCX-PJ-SF085 1.3 Max. (DC to 3GHz) 1.4 Max. (3 to 4GHz) MMCX(AR)-LP-SF085 1.5 Max. (4 to 5GHz) 1.6 Max. (5 to 6GHz) Materials / Finish Component Material Finish Shell Brass Stainless steel (Conversion Adapter) Gold Plating Male Center Contact Phosphor Bronze Gold Plating Female Center Contact Beryllium Copper Gold Plating In-line Contact (Male/Female) Beryllium Copper (Conversion Adapter) Gold Plating Insulator PTFE Resin Securing Ring Beryllium Copper (Plug) Gold Plating Crimp Sleeve Bronze Gold Plating Cap Brass (Plug) Gold Plating - 4 MMCX Series/Ultra-small Push-on Coaxial Connector Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ■ Standard Type MMCX - LP - 066 (40) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸ ❹ ❶ Series Name MMCX ❸ Applicable Cable /PCB Mounting Style 178B/U 316/U FHSB 088 066 SF085 PC SMT ❷ Connector Type P : Straight Plug LP : Right Angle Plug PJ, BPJ : Pannel Jack J : Straight Jack LR : Right Angle Receptacle R : Receptacle ❹ Specifications RoHS2 Compliant : RG-178B/U ( φ 1.8) : RG-316/U ( φ 2.59 Max.) : φ 1.48 (Single Shielded Cable)  Coaxial Fluororesin Cable : φ 1.37 (Single Shielded Cable)  Coaxial Fluororesin Cable : φ 1.32 (Double Shielded Cable)  Coaxial Fluororesin Cable : φ 1.13 (Single Shielded Cable)  Coaxial Fluororesin Cable :External Conductor Diameter  Equivalent to 0.085 Inches  (With Jacket Finishing Diameter   is φ 2.5) : PCB Through Hole Type : PCB SMT Mounting Type Examples of Mated Condition Right Angle Receptacle + Straight Plug Straight Receptacle + Straight Plug Right Angle Receptacle + Right Angle Plug Straight Receptacle + Right Angle Plug 5 MMCX Series/Ultra-small Push-on Coaxial Connector Interface Dimensions [Jack] REF.PLANE [Plug] 2.59 Min. 1.6±0.03 2.69 Min. 1.48±0.02 0.1+0.15 -0.1 0.23 Max. 0.2 Max. φ0.7±0.02 60 ° φ3.02±0.02 φ2.88±0.02 1.4 Min. 15 φ0.4±0.02 2.32±0.02 70 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.05±0.15 φ1.6±0.02 φ2.38±0.02 REF.PLANE ° 30 ° [Reference] MMCX-R-SMT-8 High Frequency Characteristics ■Insertion Loss ■V.S.W.R. Test Bord 6 MMCX Series/Ultra-small Push-on Coaxial Connector Right Angle Plug ● For φ1.32 Double Shielded Cable For φ1.13 Single Shielded Cable Connects with U. FL- LP- 066HF( 06) . φ1.27 7.5 7 5.25 φ3 4 Part No. MMCX-LP-066(40) ● HRS No. Purchase Unit CL0339-0019-2-40 20pcs per bag For φ1.37 Single Shielded Cable Connects with U. FL- LP- 088HF( 06) . φ1.9 φ0.96 11 7 5.25 4 Part No. MMCX-LP-088(40) Purchase Unit CL0339-0020-1-40 20pcs per bag For φ1.48 Single Shielded Cable 7 Part No. MMCX-LP-FHSB(40) 11 φ0.9 4 φ1.9 ● HRS No. 5.25 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. φ3 10 HRS No. CL0339-0007-3-40 7 Purchase Unit 100pcs per bag MMCX Series/Ultra-small Push-on Coaxial Connector ● For RG-178B/U Cable 7 HRS No. Purchase Unit CL0339-0001-7-40 20pcs per bag For RG-316/U Cable φ1.6 11 7 φ3 4 5.25 12 φ3.5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● φ0.9 5.25 Part No. MMCX-LP-178B/U(40) φ2.4 11 4 Part No. HRS No. Remarks MMCX-LP-316/U(40) CL0339-0006-0-40 We accept cable assembly specifications. Please contact a Hirose sales representative. 8 MMCX Series/Ultra-small Push-on Coaxial Connector Straight Plug For φ1.32 Double Shielded Cable   For φ1.13 Single Shielded Cable ● Connects with U. FL- LP- 066HF( 06) . φ4 φ3.9 13.7 Part No. MMCX-P-066(40) ● HRS No. Purchase Unit CL0339-0023-0-40 100pcs per bag For φ1.37 Single Shielded Cable Connects with U. FL- LP- 088HF( 06) . 14 φ4 φ0.96 φ1.9 7 Part No. MMCX-P-088(40) ● HRS No. Purchase Unit CL0339-0021-4-40 20pcs per bag For φ1.48 Single Shielded Cable φ0.93 φ1.9 14 7 φ4 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. φ4 10 Part No. MMCX-P-FHSB(40) HRS No. CL0339-0008-6-40 9 Purchase Unit 100pcs per bag MMCX Series/Ultra-small Push-on Coaxial Connector ● For RG-178B/U Cable φ0.93 φ4 φ2.4 14 7 Part No. Purchase Unit CL0339-0010-8-40 20pcs per bag Straight Jack ● For RG-178B/U Cable 14.8 φ2.4 φ0.93 7.8 φ4 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MMCX-P-178B/U(40) HRS No. Part No. MMCX-J-178B/U(40) HRS No. CL0339-0011-0-40 10 Purchase Unit 100pcs per bag MMCX Series/Ultra-small Push-on Coaxial Connector Panel Jack For φ1.32 Double Shielded Cable   For φ1.13 Single Shielded Cable ● Connects with U. FL- LP- 066HF( 06) . 0.8 5.1 φ3.9 φ7 φ7.7 φ3.6 8.6 6.5HEX No.10-32UNF-2A Part No. HRS No. Remarks MMCX-BPJ-066(40) CL0339-0016-4-40 We accept cable assembly specifications. Please contact a Hirose sales representative. 1 +0 0 .1 ■ Panel Cut-Out Dimensions φ 6. +0.1 0 5.1 Recommended Panel Thickness : 1.3 to 2.5mm ● For Semi-flexible Cable (Low Loss Type) External conductor diameter equivalent to 0. 085 Inches. ( With jacket finishing diameter is φ2. 5. ) (10.7) (7.2) φ19.5±0.3 17±0.2 φ17.5±0.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. φ4 10 Part No. HRS No. Remarks MMCX-PJ-SF085 CL0339-0045-0-00 We accept cable assembly specifications. Please contact a Hirose sales representative. 11 MMCX Series/Ultra-small Push-on Coaxial Connector Receptacle ● For Straight SMT φ3.5 3.5 1.7 φ0.75 3.5 Part No. 4.69 HRS No. MMCX-R-SMT-8 Purchase Unit CL0339-0046-0-00 500pcs per reel ■ Recommended PCB Layout 37±0.05 37±0.05 15±0.03 φ9±0.05 φ20.8±0.03 ● For Right Angle SMT 7.37 4.45 Part No. HRS No. MMCX-LR-SMT(40) CL0339-0003-2-40 ■ Recommended PCB Layout 7±0.05 4.6±0.1 2±0.1 4×φ1±0.1 3.5±0.1 3.5±0.1 4.5±0.05 7.5±0.05 3.5 +0.1 0 2 1.1 12 φ4.47 φ0.7 1.4 3.4 3.51 1±0.03 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1 Purchase Unit 50pcs per tray MMCX Series/Ultra-small Push-on Coaxial Connector ● For Straight Through-Hole 3.5 7.37 Part No. 4-0.5 φ3.5 φ0.7 4.45 HRS No. Purchase Unit CL0339-0005-8-40 100pcs per bag ■ Recommended PCB Dimensions 2.54±0.05 2.54±0.05 5-φ 0.9 +0 .1 0 For Right Angle Through-Hole 3.5 6.8 3.8 2.1 4.75 4-0.5 2.54 3.5 4-0.5 φ0.7 2.54 6.5 ● φ3.5 Part No. MMCX-LR-PC-1(40) HRS No. CL0339-0013-6-40 ■ Recommended PCB Dimensions 2.54±0.05 2.54±0.05 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MMCX-R-PC(40) 4-0.5 2.54 3.5 2.54 5-φ 0.9 +0 .1 0 13 Purchase Unit 10pcs per bag MMCX Series/Ultra-small Push-on Coaxial Connector Conversion Adapter ● SMA Conversion Adapter (Mated Portion : SMA Plug - MMCX Jack) 8HEX Part No. HRMP-MMCXJ HRS No. Purchase Unit CL0311-0312-1-00 20pcs per bag Note : Can be used with standard type and outer conductor contact reinforced type (MMCX[AR]) MMCX plugs. ● SMA Conversion Adapter (Mated Portion : SMA Jack - MMCX Plug) 14 4.05 6 φ6.35 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. φ4 1/4 -36UNS-2B 13.74 Spanner Engaged Width : 5.6 Part No. HRMJ-MMCXP HRS No. CL0311-0313-4-00 1/4_36UNS_2A Purchase Unit 20pcs per bag 14 MMCX Series/Ultra-small Push-on Coaxial Connector Plug/Jack Termination Tools Item Part No. MMCX-LP-066(40) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Straight Jack Usage CL0902-3064-6-00 Cap Press Fitting HT103/MRF01-J-178 CL0350-0128-5-00 Outer Conductor Tightening MMCX-LP/PR-MP CL0902-3064-6-00 Cap Press Fitting HT103/MRF01-J-178 CL0350-0128-5-00 Outer Conductor Tightening MMCX-LP/PR-MP CL0902-3064-6-00 Cap Press Fitting HT103/MRF01-J-178 CL0350-0128-5-00 Outer Conductor Tightening MMCX-LP/PR-MP CL0902-3064-6-00 Cap Press Fitting MMCX-P-066(40) MMCX-P-066/CV-MD CL0902-3272-0-00 Clamp Press Fitting MMCX-P-088(40) HT103/MRF01-J-178 CL0350-0128-5-00 Outer Conductor Tightening MMCX-P-FHSB(40) HT103/MRF01-J-178 CL0350-0128-5-00 Outer Conductor Tightening MMCX-P-178B/U(40) HT103/MRF01-J-178 CL0350-0128-5-00 Outer Conductor Tightening MMCX-J-178B/U(40) HT103/MRF01-J-178 CL0350-0128-5-00 Outer Conductor Tightening MMCX-LP-FHSB(40) MMCX-LP-178B/U(40) Straight Plug HRS No. MMCX-LP/PR-MP MMCX-LP-088(40) Right Angle Plug Tool 15 Ultra-small Push-on Coaxial Connector [MMCX(AR)] Outer Conductor Contact Reinforced Plug Connector [MMCX(AR)] Product Number Structure MMCX(AR)- LP - 066 ❶ ❷ ❶ Series Name ❷ Outer Conductor Contact Reinforced Type ❸ Connector Type ❸ ❹ ❹ MMCX Applicable Cable or Board Mounting Style (AR) P  :Straight Plug LP :Right Angle Plug TMP:Termination Plug 178B/U FHSB 088 066 SF085 SF047 :RG-178B/U(φ 1.8) :φ 1.48 (Single Shielded Cable)  Coaxial Fluororesin Cable :φ 1.37 (Single Shielded Cable)  Coaxial Fluororesin Cable :φ 1.32 (Double Shielded Cable)  Coaxial Fluororesin Cable :φ 1.13 (Single Shielded Cable)  Coaxial Fluororesin Cable : External Conductor Diameter Equivalent to 0.085 Inches  (With Jacket Finishing Diameter is φ 2.5) :External Conductor Diameter Equivalent to 0.047 Inches (With Jacket Finishing Diameter is φ 1.44) [Reference] Semi-flexible Cable Configuration and Cable Loss Comparison Semi-flexible Cable Configuration Insertion Loss Comparison (Semi-flexible Cable & Flexible Cable) Excellent Electrical Performance Due to Tin-Coated Braided Shielding L=1m [Reference] Insertion Loss (Typical) 0 -1 -2 -3 Insertion loss [dB] Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. Cable Jacket Outer Conductor (Shielding + Tin Coating) -4 -5 Semi-flexible Cable (φ2.5/0.085 inch) -6 Flexible Cable (RG-316U) -7 Semi-flexible Cable (φ1.44/0.047 inch) -8 Flexible Cable (φ1.37) -9 Flexible Cable (φ1.13) -10 Dielectric (PTFE 0 Center Conductor (Single Wire) 16 1 2 3 4 5 Frequency [GHz] 6 7 8 Ultra-small Push-on Coaxial Connector [MMCX(AR)] Standard Type and Outer Conductor Contact Reinforced Type [MMCX(AR)] Standard Type Product : MMCX-P-### Plug ring contacts the receptacle outer conductor. Receptacle Mating Before Mating ❶ Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Plug head does not contact receptacle outer conductor (without padding) Only a single point makes contact with the outer conductor. After Mating Cross Section Outer Conductor Contact Reinforced Type [MMCX(AR)] Since the contact is strengthened compared to the standard type, mating feels tighter. Product : MMCX(AR)-P-### Plug ring contacts the receptacle outer conductor. Receptacle Mating Plug head contacts receptacle outer conductor (with padding) Before Mating ❷ ❶ Contact with the receptacle outer conductor at two points enhances prying force and ensures high contact reliability even in difficult wiring conditions. After Mating Cross Section Mating and Extraction Forces Comparison (Reference Value) (Reference Value) Mating Force Extraction Force Standard Type 15N 15N Outer Conductor Contact Reinforced Type[MMCX(AR)] 35N 25N 17 Ultra-small Push-on Coaxial Connector [MMCX(AR)] Right Angle Plug For φ1.32 Double Shielded Cable   For φ1.13 Single Shielded Cable ● Connects with U. FL- LP- 066HF( 06) . 7.5 7 5.25 φ3 φ1.27 4 Part No. MMCX(AR)-LP-066 ● HRS No. Purchase Unit CL0339-0031-8-00 20pcs per bag For φ1.48 Single Shielded Cable 11 Part No. MMCX(AR)-LP-FHSB ● φ0.9 φ1.9 5.25 7 4 HRS No. Purchase Unit CL0339-0035-9-00 100pcs per bag For RG-178B/U Cable 7 Part No. MMCX(AR)-LP-178B/U φ0.9 φ2.4 11 4 5.25 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. φ3 10 HRS No. CL0339-0033-3-00 18 Purchase Unit 100pcs per bag Ultra-small Push-on Coaxial Connector [MMCX(AR)] Straight Plug For φ1.32 Double Shielded Cable   For φ1.13 Single Shielded Cable ● Connects with U. FL- LP- 066HF( 06) . φ4 φ3.9 13.7 Part No. MMCX(AR)-P-066 ● HRS No. Purchase Unit CL0339-0030-5-00 100pcs per bag For φ1.37 Single Shielded Cable Connects with U. FL- LP- 088HF( 06) . φ0.96 φ4 φ1.9 14 7 Part No. MMCX(AR)-P-088 ● HRS No. Purchase Unit CL0339-0037-4-00 20pcs per bag For RG-178B/U Cable 14 φ2.4 φ0.93 7 φ4 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. φ4 10 Part No. MMCX(AR)-P-178B/U HRS No. CL0339-0038-7-00 19 Purchase Unit 100pcs per bag Ultra-small Push-on Coaxial Connector [MMCX(AR)] ● For Semi-flexible Cable (Low Loss Type) External conductor diameter equivalent to 0. 047 Inches. ( With jacket finishing diameter is φ1. 44. ) (φ6.25) 52.5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. φ24 18 Part No. HRS No. Remarks MMCX(AR)-P-SF047 CL0339-0032-0-00 We accept cable assembly specifications. Please contact a Hirose sales representative. 20 Ultra-small Push-on Coaxial Connector [MMCX(AR)] φ6 φ5.5 Non-reflective Terminator 6 14.5 HRS No. MMCX(AR)-TMP CL0353-0010-0-00 Electric Power(W) Purchase Unit 1/4 20pcs per bag Conversion Adapter ● SMA Conversion Adapter (Mated Portion : SMA Plug - MMCX Jack) 1/4-36UNS-2B 13.74 φ4 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. 8HEX Part No. HRS No. HRMP-MMCXJ Purchase Unit CL0311-0312-1-00 20pcs per bag Note : Can be used with standard type and outer conductor contact reinforced type (MMCX[AR]) MMCX plugs. Plug Termination Tools Item Part No. MMCX(AR)-LP-066 Right Angle Plug HRS No. Usage MMCX-LP/PR-MP CL0902-3064-6-00 Cap Press Fitting HT103/MRF01-J-178 CL0350-0128-5-00 Outer Conductor Tightening MMCX-LP/PR-MP CL0902-3064-6-00 Cap Press Fitting HT103/MRF01-J-178 CL0350-0128-5-00 Outer Conductor Tightening MMCX-LP/PR-MP CL0902-3064-6-00 Cap Press Fitting MMCX(AR)-P-066 MMCX-P-066/CV-MD CL0902-3272-0-00 Clamp Press Fitting MMCX(AR)-P-088 HT103/MRF01-J-178 CL0350-0128-5-00 Outer Conductor Tightening MMCX(AR)-P-178B/U HT103/MRF01-J-178 CL0350-0128-5-00 Outer Conductor Tightening MMCX(AR)-LP-FHSB MMCX(AR)-LP-178B/U Straight Plug Tool 21 Ultra-small Push-on Coaxial Connector [MMCX(AR)] While Taking into Consideration Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 1/ 2022. Contents are subject to change without notice for the purpose of improvements. 22 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Ultra-small Push-on Coaxial Connector [MMCX(AR)] 23
MMCX-BPJ-066(40)
物料型号:HIROSE ELECTRIC CO., LTD. 制造的MMCX系列超小型推入式同轴连接器。
器件简介:这是一种超小型推入式同轴连接器,具有易于连接和断开的推入系统,适用于高频应用。
引脚分配:文档中未明确列出引脚分配,但通常这类连接器为同轴设计,中心引脚为信号传输,外圈为接地。
参数特性: - 特性阻抗:50欧姆 - 额定频率:直流至8GHz - 操作温度:-55至+85°C - 绝缘电阻:最小500MΩ - 耐电压:500V交流1分钟无击穿或绝缘破坏 - 接触电阻:中心接触10mΩ最大,外圈接触5mΩ最大 - 保持力:女性接触0.2至2N - 插入/拔出力量:插入力量最大15N,拔出力量6至15N(标准型),拔出力量最小6N(外导体接触加强型[MMCX(AR)])
功能详解: - 提供了适用于不同类型电缆的连接器,包括RG型高频同轴电缆和超细氟树脂电缆。 - 与其他Hirose系列(如H.FL, U.FL, SMA, SMA(R))的双端电缆组件兼容。 - 提供了两种类型的插头,包括标准型和外导体接触加强型。 - 符合RoHS2标准。
应用信息:适用于无线局域网、GPS、销售点终端、测量仪器、传输设备内部布线等。
封装信息:提供了详细的产品规格和订购信息,包括不同的安装风格(如SMT、通孔)和连接器类型(如直插头、直角插头、面板插座)。
MMCX-BPJ-066(40) 价格&库存
很抱歉,暂时无法提供与“MMCX-BPJ-066(40)”相匹配的价格&库存,您可以联系我们找货
