1279-4002
1279-4002
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPPLUGSTR50OHMSOLDER
1279-4002 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING DATE APPROVED - DCN 37509 04/10 STW A DCN 42247 04/16 FSG .129 MIN 3.28 MIN .262 6.65 .256±.001 6.50±0.03 .268±.002 6.81±0.05 .225 5.72 A .154 MIN 3.91 MIN .110 2.79 .0345±.0005 0.88±0.01 10-32 UNF-2B .137 3.48 SMP MALE LD .232 MIN 5.89 MIN THD RECOMMENDED MOUNTING HOLE .217 5.51 MATERIAL: BODY & BUSHING: 2X .043 1.09 WIDE SLOT .015±.001 0.38±0.03 BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 CENTER PIN & OUTER RING: KOVAR PER ASTM-F15 GLASS: CORNING #7070 .050 1.27 10-32 UNF-2A .040 1.02 FINISH: BODY & BUSHING: CENTER PIN & OUTER RING: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. GOLD PER ASTM B 488, TYPE I, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: MATERIAL: FINISH: IMPEDANCE: FREQ. RANGE: VSWR: TEMP. RATING: 50 OHMS DC TO 26.5 GHz 1.25:1 DC TO 18.0 GHz 1.35:1 DC TO 26.5 GHz -65 C TO +165 C SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: FED 04/27/10 CHECKED: APPROVED: STW 04/27/10 STW 04/27/10 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMP MALE, THREADED HERMETIC LD SHROUD FEED THROUGH CONNECTOR SIZE CAGE CODE DWG. NO. B 95077 SCALE: 12:1 1279-4002 SHEET 1 OF 1
1279-4002 价格&库存
很抱歉,暂时无法提供与“1279-4002”相匹配的价格&库存,您可以联系我们找货
  • 1+851.210611+110.17710
