5021-00026
5021-00026
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNNJACKSTR50OHMSOLDER
5021-00026 数据手册
PRODUCT DATA DRAWING ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV - DCN 40883 DATE APPROVED 10/14 STW 5/8-24UNEF-2A .866 .531 13.5 ACROSS FLATS 22 .827 21 .945 24 .118 3 MATERIAL: BODY: BRASS CONTACT: BERYLLIUM COPPER INSULATOR: PTFE NOTES: 1. FINISH: BODY: NICKEL CONTACT: GOLD FINISH: PERFORMANCE: OPERATING TEMP.: MATERIAL: SEE NOTES SEE NOTES SURFACE AREA: -55 C TO +125 C INTERFACE : IEC 169-16 MIL-C-39012, N N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 .030 .010 .005 ANGULAR: X X X' 1 0' 15' INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: MAL 10/23/14 CHECKED: APPROVED: STW 10/23/14 STW 10/23/14 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SIZE B N JACK BULKHEAD FOR .085 CABLE (SOLDER) CAGE CODE DWG. NO. 5021-00026 95077 SCALE: 3:1 SHEET 1 OF 1
5021-00026 价格&库存
很抱歉,暂时无法提供与“5021-00026”相匹配的价格&库存,您可以联系我们找货
  • 1+652.359871+84.64066
