3285-6001-TD
3285-6001-TD
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPMPLUGSTR50OHMEDGEMNT
3285-6001-TD 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING - CO-PLANARITY BETWEEN SURFACE "A" AND CONTACT IS -.000/+.005 .125 3.18 2X .056 1.42 .165 4.19 REVISION HISTORY DESCRIPTION REV DCN 47138 DATE APPROVED 01/18 STW A .007 0.18 2X.031 0.79 .120 3.05 .120 3.05 .012 0.30 .157 3.99 .043 1.09 +.002 +0.05 .079 - .000 2.01 0 2X.012 0.30 .165 4.19 NOTES: 1. 2. GROUND .090 MAX 2.29 MAX TO BE TIN DIPPED USING Sn96 SOLDER. ALL DIMENSIONS APPLY PRIOR TO SOLDER DIPPING. MATERIAL: BODY: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B .125 3.18 .015 MIN 0.38 MIN FINISH: TRACE BODY& CONTACT: GOLD PER ASTM B 488, TYPE II, GRADE C, CLASS .76, OVER NICKEL PER AMS-QQ-N-290, CLASS 1. PERFORMANCE: PREPARE P.C.B. AS SHOWN MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: IMPEDANCE: DWV: FREQ. RANGE: INSUL. RES: 50 OHMS. 325 VRMS. DC TO 40.0 GHz. 5000 MEGOHMS, MIN. N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .002 T.I.R. 7) REMOVE ALL BURRS DRAWN: FSG 04/27/16 CHECKED: APPROVED: MAL 04/27/16 MAL 04/27/16 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMPM MALE FD EDGE MOUNT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 16:1 3285-6001-TD SHEET 1 OF 1
3285-6001-TD 价格&库存
很抱歉,暂时无法提供与“3285-6001-TD”相匹配的价格&库存,您可以联系我们找货
3285-6001-TD
  • 1+1239.902411+160.71496
