138-4307-407
138-4307-407
    CINCH
    CONN N JACK STR 50 OHM SOLDER
138-4307-407 数据手册
Type N Bulkhead Jack Crimp Style for RG-58, 142, 213, 214 and LMR-400 Flexible Cable 1. Identify connector parts. (6 piece parts) 2. Strip cable to dimensions shown. Do not nick center conductor. A wire stripper of correct size is recommended for this step. Tin center conductor if contact will be solder attached. Do not tin center conductor if contact will be crimp attached. Slide crimp sleeve onto jacket of cable. 3. Assemble jack contact onto cable as shown. Jack contact should butt against cable dielectric during attachment. Solder Attachment: Solder jack contact to center conductor through solder hole using .020 (.051) diameter flux core solder wire. Use a minimum amount of solder for a good joint. Crimp Attachment: Crimp jack contact to center conductor using Johnson ergonomic hand crimp frame 140-0000-967 with recommended hex size die set. Crimp location should be on end of jack contact next to cable dielectric. Crimp attachment to solid center conductor cables is not recommended. 4. Flare braid and slide bulkhead jack connector assembly over jack contact and under braid. Seat bulkhead jack connector assembly firmly onto contact. Arrange braid uniformly around crimp stem. Slide crimp sleeve forward and crimp using Johnson ergonomic hand crimp frame 140-0000-967 with recommended hex size die set. Maintain forward pressure on cable while crimping. Part No. “A” “B” Crimp Sleeve “C” Contact Hex Size Hex Size RG-58/U, 141, 303 138-4307-407 .310 (7.87) .389 (9.88) .135 (3.43) .213 (5.41) .068 (1.73) RG-55/U, 142, 223, 400 138-4308-407 .310 (7.87) .389 (9.88) .135 (3.43) .213 (5.41) .068 (1.73) RG-8, 213 138-4316-407 .385 (9.78) .400 (10.16) .165 (4.19) .429 (10.90) .111 (2.82) RG-9, 214 138-4318-407 .385 (9.78) .400 (10.16) .165 (4.19) .429 (10.90) .111 (2.82) Cable Group Assembly Tool 138-4307/4308-407 138-4316/4318/4349-407 Crimp Frame 140-0000-967 140-0000-967 Die Set 140-0000-990 140-0000-991 271 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
138-4307-407 价格&库存
很抱歉,暂时无法提供与“138-4307-407”相匹配的价格&库存,您可以联系我们找货
