GRF1-J-P-06-E-RA-TH1-E 数据手册
GRF1–P–P–08–E–ST–TH1
F-221 WEB
GRF1–P–P–04–E–ST–TH1
GRF1–J–P–04–E–ST–TH1–E
(5.00 mm) .197"
GRF1-J, GRF1-P SERIES
50 W GANGED MICRO-MINI RF SYSTEMS
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?GRF1-J or
www.samtec.com?GRF1-P
Shell Material:
Brass
Insulator Material:
PTFE
Contact Material:
BeCu
Pin Material:
Brass
Plating:
30 µ" (0.76 µm) Au
over 50 µ" (1.27 µm) Ni
Current Rating
(GRF1-J/GRF1-P):
Signals: 3.6 A per pin
(8 adjacent pins powered)
Grounds: 6.2 A per pin
Operating Temp Range:
-40 °C to +90 °C
Impedance:
50 W
Dielectric
Withstanding Voltage:
500 Vrms, 50 Hz
Dielectric Working Voltage:
170 Vrms, 50 Hz
Frequency Range:
0~6 GHz
RoHS Compliant:
Yes
NO. OF
JACKS
P
J
GRF1
Mates with:
GRF1-P, GRF1-C,
GRF1H-C
–02, –04,
–06, –08
PLATING
LEAD
STYLE
–E
= Vertical
–ST
= 30 µ" (0.76 µm)
Gold on Center
Conductor & Tail,
Gold Flash on
Shell and Tails
INSERT
OPTION
TH1
–E
= #1 - 64 Through-hole
Threaded Insert,
Mates with GRF1-C with
captive screw option
–RA
= Rightangle
No. of Jacks x (5.00) .197 + (12.20) .480
+ (7.20) .283
(5.00)
.197
(6.68)
.263
(6.88)
.271
(5.00) .197
(3.50)
.138
(2.80)
.110
(4.60)
.181
(0.50)
.020 SQ
(0.70)
.028 DIA
–RA
SHOWN
(2.80)
.110
–ST–TH1–E
SHOWN
PROCESSING
(2.71)
.107
(5.20)
.205
Lead–Free Solderable:
Yes
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
GRF1
Mates with:
GRF1-J
FILE NO. E111594
APPLICATION
P
P
NO. OF
PLUGS
–02, –04, –06, –08
ST
PLATING
TH1
–E
= 30 µ" (0.76 µm) Gold on Center Conductor & Tail,
Gold Flash on Shell and Tails
No. of Plugs x (5.00) .197
GRF1-J
(5.00)
.197
(6.40)
.252
(5.00)
.197
GRF1-P
(2.70)
.106
OTHER
SOLUTIONS
(2.70) .106 DIA
(1.80)
.071
(4.50)
.177
• Cable assembly
(see GRF1-C Series)
(0.50)
.020 SQ
(2.80)
.110
(2.00)
.079
(0.70)
.028 DIA
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
GRF1-J-P-06-E-RA-TH1-E 价格&库存
很抱歉,暂时无法提供与“GRF1-J-P-06-E-RA-TH1-E”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 13+267.81570
- 26+246.39045
- 52+214.24047
- 104+193.14167
- 260+186.20144
- 507+172.13960
