ERA.0E.650.CTL
ERA.0E.650.CTL
    LEMO(雷莫)
    ERA.0E.650.CTL
ERA.0E.650.CTL 数据手册
ERA.0E.650.CTL www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 0E Termination type Female solder IP rating 68 when mated AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FFA.0E.650.CLAC10 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model ERA*: Fixed receptacle, nut fixing Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 12.24 g Performance Configuration 0E.650 : 1 Triax (50 Ohm) Insulator T: PTFE Rated Current 6 Amps Specifications Contact Type: Solder Vtest: 1200 V (AC), 1690 V (DC) Impedance: 50 Ohm VSWR: 1.03 + 0.34 * f/GHz Cable type: RGT 178, RGT 174 Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L L1 M S1 e mm. 18 19.2 5.5 19.5 20.5 4 12.5 M14x1.0 in. 0,71 0,76 0,22 0,77 0,81 0,16 0,49 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
ERA.0E.650.CTL 价格&库存
很抱歉,暂时无法提供与“ERA.0E.650.CTL”相匹配的价格&库存,您可以联系我们找货
