HVR.03.250.CLLPV
HVR.03.250.CLLPV
    LEMO(雷莫)
    HVR.03.250.CLLPV
HVR.03.250.CLLPV 数据手册
HVR.03.250.CLLPV www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 03 Termination type Female solder IP rating 68 when mated AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model HVR.03*: Fixed receptacle, hexagonal flange, Keying Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant PV : Watertight / Vacuum-tested unmated Weight 4.53 g Performance Configuration 03.250 : 1 Coax (50 Ohm) Insulator Rated Current Specifications Contact Type: Solder Others Temp (min / max): -20°C / +100°C Humidity (max): 1000 hr Pressure: 60 bars (120 bars with LEMO cable assembly) DRAWINGS Dimensions A B E L M S1 S2 e mm. 11.8 10.2 6.5 21 6 11 9 M7x0.5 in. 0,46 0,40 0,26 0,83 0,24 0,43 0,35 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
HVR.03.250.CLLPV 价格&库存
很抱歉,暂时无法提供与“HVR.03.250.CLLPV”相匹配的价格&库存,您可以联系我们找货
HVR.03.250.CLLPV
  • 50+244.8225850+31.63894
