FLA.00.650.CLAC35
www.lemo.com
SUMMARY
# Wires
Triax
1
Image is for illustrative purpose only
Series
00
Termination type
Male solder
IP rating
50
AWG wire size
0.00 - 0.00
Cable Ø
0.00 - 0.00 mm
Status
active
Matching parts
ERN.00.650.CLL
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FLA*: Elbow plug with cable collet
Keying
Circular, male
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
5.76 g
Performance
Configuration
00.650 : 1 Triax (50 Ohm)
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
3 Amps
Specifications
Contact Type: Triaxial 50 Ohm (Solder)
Contact Dia.: 0.5 mm (0.02"in)
Vtest: 1200 V (AC), 1700 V (DC)
Impedance: 50 Ohm
VSWR: 1.1 + 0.11 * f/GHz
Cable type: RGT 403
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/2
Endurance (Shell): 5000 mating cycles
Salt Spray Corrosion: >1000 hr
DRAWINGS
Dimensions
A
L
M
mm.
9
17.5
9.5
in.
0,35
0,69
0,37
RECOMMENDED BY LEMO
Tools
Spanner wrench:
DCD.00.ZZZ.PA050
2/2
很抱歉,暂时无法提供与“FLA.00.650.CLAC35”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+265.7274250+34.47792
