PL375-33
PL375-33
    CINCH
    CONN TRT PLUG STR SOLDER
PL375-33 数据手册
DWG NO. -27 -29 -30 -32 -33 -42 -43 -45 -46 -47 -49 -54 -55 -56 -57 -58 -59 -60 -64 6 .750 .345 TAI-103 .438 .500 .285 TAI-102 .455 .130 .625 .688 .750 .485 .362 .352 .490 .183 .191 .200 .285 .191 .145 .096 .438 .438 .500 .191 TWINAX TAI-103 TAI-128 TAI-129 TAI-165 TRIAX TAI-129 TAI-189 TAI-102 TWINAX TAI-189 TRIAX TAI-102 TWINAX TAI-189 TRIAX TAI-102 TWINAX .235 .191 .217 .300 TAI-189 TRIAX .200 .130 .096 .625 .438 .688 .438 .750 .500 .130 .625 .688 .750 .096 .438 .438 .500 .183 .475 .164 .132 .323 .250 .191 .198 .217 .183 IF SAFETY WIRE TYP&E BEND RELIEF SPRING REQD ADD SUFFIX "SBR" TO MODEL NO (NOT AVAILABLE WITH CABLE GROUPS -8, -10, -11, -12, -13,-13A, -14, -&46-,54) IF BEND RELIEF SPRING REQD (SEE FIG 2) ADD SUFFIX "BR" TO MODEL NO (NOT AVAILABLE WITH CABLE GROUPS -8, -10, -11, -12, -13, -13A, -14, &-46, -54) 4. IF SAFETY WIRE TYPE REQD ADD SUFFIX "S" TO MODEL NO (PL375S) 3 CLAMP NUT OMITTED 2. CONCENTRIC TWINAX/TRIAX TRT CABLE PLUG U N 5 1 .347 PY .688 TRIAX TAI-103 TAI-102 5 6 TAI-189 TRIAX TAI-189 TRIAX "B" A .030 .029 .002 3 PLACES EQUALLY SPACED APPROVED CSM .650 MAXIMUM OVER KNURL "E" BODY DIAMETER "D" WRENCH FLATS 5 DATE 6/18/10 "C" HEX SIZE SAFTEY WIRE OPTION TWINAX TAI-103 TAI-102 2.00 MAXIMUM PL375S-9 SHOWN PL375-9BR SHOWN TAI-102 REVISIONS DESCRIPTIONS O 3 TAI-189 CUST. REV CUSTOMER P/N C -13 -13A -14 -23 -24 -24A -25 -25A -26 3 .274 ED -12 .438 .500 LL -11 .625 .096 .438 DATA CONTAINED IN THIS DOCUMENT IS PROPRIETARY TO EMERSON CONNECTIVITY SOLUTIONS AND SHALL NOT REV BE DISCLOSED, COPIED OR USED FOR PROCUMENT OR MANUFACTURE WITHOUT EXPRESS WRITTEN PERMISSION AD ECO 52460 CABLE ASSEMBLE CABLE ENTRY DIA PER TYPE O -10 .130 .438 E DIA CABLE ENTRY 6 2.00 MAXIMUM TR -A9 3 .096 TABLE 1 C D FLATS FLATS 1 A .030 TAI-102 QUADRAX N -8 -9 B DIM O -7 CABLES A ACCOMMODATED DIM TRC-50-2 1.165 TRC-75-2 8227, BELDEN 1.740 TWC-78-2 TWC-124-2 BL782, TIMES 1.165 BL982, TIMES BL1242, TIMES RG-22 754E, AT&T 760A, AT&T 16PEVL, A& TT 1.740 V1-AL, GENERAL TRF-59, TIMES 8232, BELDEN 8233, BELDEN 250-3884, MICRODOT 202-3934, MICRODOT 9530A5117, RAYCHEM T-43M, GENERAL 5021H5331, RAYCHEM 7028A5518, RAYCHEM T19TPSJ2619EN, WOVEN 202-3927, MICRODOT 202-3942, MICRODOT TWC-78-1/TWC-124-1A 1.165 761A, AT&T 8441, BELDEN TRC-50-1 TRC-75-1 21-204, ESSEX 4463, CONSOLIDATED 250-4044/250-4045 293-3930, MICRODOT M27500-22TE2T14 1100-66F, STANDARD 9860, BELDEN 1.740 M17/176-00002 1.165 TWAC-78-1F2 89207, BELDEN 1.740 89272, BELDEN GC875GCI, GRUMMAN GC875GB1, GRUMMAN GC875TM24H, GRUMMAN 1.165 GC875LN1, GRUMMAN M17/177, THERMATICS 380-10045, BOEING 7528A5314, RAYCHEM 7. FINISH: TFS-1A (NICKEL) NOTES: UNLESS OTHERWISE SPECIFIED. BASIC MODEL NO SAFETY WIRE TYPE (OMIT IF NOT REQD) 1.846 .125 "D" WRENCH FLATS EXAMPLE OF COMPLETE MODEL NO: PL375 S -7 BR C DASH NO CUSTOMER SH 315-0011 BEND RELIEF (OMIT IF NOT REQD) DASH NO (CABLE GROUP, TABLE 1) N/A BLANK LENGTH (REF. ONLY) N/A SURFACE AREA INTERPRET DRAWING PER .XX .02 MIL-STD-100. .010 DIMENSIONS ARE IN INCHES .XXX AND INCLUDE FINISH .XXXX .0010 THICKNESS ANGLE 1 00' UNLESS OTHERWISE SPECIFIED. CRITICAL DRN CHK BPK 7/29/11 CSM 8/1/11 QUALITY MATERIAL: FINISH: MANUF APPROVED PRO/E FILE NO. 315-0011 1 TITLE: PL375 / PL375S PL375BR / PL375SBR SIZE CAGE CODE DRAWING NO. A 14949 315-0011 SCALE DO NOT SCALE DWG 1/1 DATE 5/23/73 REV. SHEET AD 1 OF 2
PL375-33 价格&库存
很抱歉,暂时无法提供与“PL375-33”相匹配的价格&库存,您可以联系我们找货
