FFC.00.650.GLAC22Z
FFC.00.650.GLAC22Z
    LEMO(雷莫)
    FFC.00.650.GLAC22Z
FFC.00.650.GLAC22Z 数据手册
FFC.00.650.GLAC22Z www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 00 Termination type Male solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 1.70 - 2.10 mm Status active Matching parts ERN.00.650.GLL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFC*: Straight plug with flats on latch sleeve and cable collet, black POM (Delrin® outershell) Keying Circular, male Housing Material PEEK (Polyetheretherketone) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 2.70 g Performance Configuration 00.650 : 1 Triax (50 Ohm) Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 3 Amps Specifications Contact Type: Triaxial 50 Ohm (Solder) Contact Dia.: 0.5 mm (0.02"in) Vtest: 1200 V (AC), 1700 V (DC) Impedance: 50 Ohm VSWR: 1.1 + 0.11 * f/GHz LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Others Endurance (Shell): 5000 mating cycles DRAWINGS RECOMMENDED BY LEMO Tools Spanner wrench: DCD.00.ZZZ.PA050 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
FFC.00.650.GLAC22Z 价格&库存
很抱歉,暂时无法提供与“FFC.00.650.GLAC22Z”相匹配的价格&库存,您可以联系我们找货
