FLA.00.250.NTAC27
FLA.00.250.NTAC27
    LEMO(雷莫)
    FLA.00.250.NTAC27
FLA.00.250.NTAC27 数据手册
FLA.00.250.NTAC27 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 00 Termination type Male solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 2.30 - 2.70 mm Status active Matching parts ERA.00.250.NTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FLA*: Elbow plug with cable collet Keying Circular, male Housing Material Brass (nickel plated [SAE AMS QQ N 290]) shell, collet nut, latch sleeve and mid pieces Weight 5.04 g Performance Configuration 00.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 4 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.6 mm (0.024in) Test voltage: 2.1 kV (rms) R (max): 6.1 mOhm Vtest: 2100 V (AC), 3000 V (DC) Impedance: 50 Ohm VSWR: 1.09 + 0.11 * f/GHz LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Cable type: RG 179 B/U Others Endurance (Shell): 5000 mating cycles F ret (min): 100 N Salt Spray Corrosion: >144 hr DRAWINGS Dimensions A L M mm. 9 17.5 9.5 in. 0,35 0,69 0,37 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.00.ZZZ.PA050 Cables LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 17450 COPOLYMER Black 18700 PTFE White 18800 PTFE White CCX.50.RG0.58AU14B FEP White CCX.50.RG1.74-U25N PVC Black CCX.50.RG1.74U25N PVC Black CCX.50.RG1.88AU24B TFE White CCX.50.RG1.88AU26B PFA White CCX.50.RG1.88AU26B PTFE White CCX.50.RG3.16BU26M FEP Brown CCX.75.RG1.79BU26M FEP Brown CCX.75.RG1.87AU26B PFA White CCX.75.RG1.87AU27B PTFE White LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FLA.00.250.NTAC27
物料型号:FLA.00.250.NTAC27,由LEMO公司生产。
器件简介:这是一种带有电缆卡箍的弯头插座,具有圆形的男性键槽。
引脚分配:1个同轴电缆。
参数特性: - 配置:1个50欧姆的同轴电缆。 - 绝缘体:PTFE。 - 额定电流:4安培。 - 接触类型:同轴50欧姆(焊接)。 - 接触直径:0.7毫米。 - 桶直径:0.6毫米。 - 测试电压:2.1千伏(有效值)。 - 最大阻抗:6.1毫欧姆。 - VSWR:1.09 + 0.11 f/GHz。
功能详解:该连接器设计用于高耐久性和性能,适用于需要高可靠性的应用。
应用信息:文档未提供具体的应用场景,但LEMO的产品通常用于医疗、工业、音频/视频和通信领域。
封装信息:提供了详细的机械和性能规格,以及推荐的LEMO工具和电缆。还包括了图纸和尺寸信息。
FLA.00.250.NTAC27 价格&库存
很抱歉,暂时无法提供与“FLA.00.250.NTAC27”相匹配的价格&库存,您可以联系我们找货
FLA.00.250.NTAC27
  • 1+389.244691+50.35475
库存:1
