FFA.1S.275.CTAC52Z
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
1S
Termination type
Male solder Coaxial
IP rating
50
AWG wire size
0.00 - 0.00
Cable Ø
4.20 - 5.20 mm
Status
active
Matching parts
ERA.1S.275.CTL
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FFA*: Straight plug, cable collet and nut for fitting a bend relief
Keying
Circular, male
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Variant
Z : Nut for fitting a bend relief
Weight
14.53 g
Performance
Configuration
1S.275 : 1 Coax (75 Ohm)
Insulator
T: PTFE
Rated Current
10 Amps
Specifications
Contact Type: Coaxial 75 Ohm (Solder)
Contact Dia.: 1.3 mm (0.0512in)
Bucket Dia.: 1.1 mm (0.0432in)
Vtest: 2400 V (AC), 3300 V (DC)
Impedance: 75 Ohm
VSWR: 1.02 + 0.08 * f/GHz
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Cable type: RG 179 B/U, RG 187 A/U, RG 58 C/U, RG 302 /U, RG 400 /U, 2YCCY, RG 59 B/U, RG 223 /U, HF-5408
Others
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +250°C
Humidity (max): 144 hr
DRAWINGS
Dimensions
A
L
M
S2
mm.
12
42.5
31.5
9
in.
0,47
1,67
1,24
0,35
RECOMMENDED BY LEMO
Tools
2/3
Spanner wrench:
DCD.1B.ZZZ.PA090
Cables
158480
PUR
Black
158490
PVC
Black
CCX.50.088.292495N
PVC
Black
CCX.50.RG5.8CU50N
PVC
Black
3/3
很抱歉,暂时无法提供与“FFA.1S.275.CTAC52Z”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+363.457101+46.29100
- 10+306.9916010+39.09930
- 25+304.6593025+38.80230
- 50+299.7264050+38.17400
- 100+294.88690100+37.55770
- 250+287.17860250+36.57590
