EPL.0S.250.DTN
EPL.0S.250.DTN
    LEMO(雷莫)
    插件
    EPL.0S.250.DTN
EPL.0S.250.DTN 数据手册
EPL.0S.250.DTN www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 0S Termination type Female print PCB Coaxial IP rating 50 AWG wire size 0.00 - 0.00 PCB Altium Pattern Cable Ø 0.00 - 0.00 mm PCB KiCad Pattern Status active Catalog Download Request a quote PCB Eagle Pattern TECHNICAL DETAILS Mechanics Shell Style/Model EPL*: Elbow receptacle for printed circuit Keying Circular, female Housing Material Brass (gold plated [ISO 27874]) shell, collet nut, brass latch sleeve and mid pieces Weight 6.20 g Performance Configuration 0S.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 6 Amps Specifications Contact Type: Coaxial 50 Ohm (PCB) Contact Dia.: 0.9 mm (0.04in) Bucket Dia.: 1 mm (0.04in) Test Voltage(kV rms) 1.2 Cable type: RG 178 B/U, RG 196 A/U, RG 188 A/U, RG 316 B/U, RG 174 A/U, HF-2114, RG 122 /U Others Endurance (Shell): 5000 mating cycles LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Temp (min / max): -55°C / +250°C Humidity (max):
EPL.0S.250.DTN 价格&库存
很抱歉,暂时无法提供与“EPL.0S.250.DTN”相匹配的价格&库存,您可以联系我们找货
