FAA.1S.650.CTA
FAA.1S.650.CTA
    LEMO(雷莫)
    FAA.1S.650.CTA
FAA.1S.650.CTA 数据手册
FAA.1S.650.CTA www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 1S Termination type Male solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts PCA.1S.650.CTLC32 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FAA*: Fixed plug, non-latching, nut fixing Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 9.88 g Performance Configuration 1S.650 : 1 Triax (50 Ohm) Insulator T: PTFE Rated Current 6 Amps Specifications Contact Type: Triaxial 50 Ohm (Solder) Contact Dia.: 0.9 mm (0.035in) Vtest: 1200 V (AC), 1700 V (DC) Impedance: 50 Ohm VSWR: 1.01 + 0.17 * f/GHz Cable type: RGT 178, RGT 174,Belden 9222 Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A B E L M S1 S3 e mm. 14 16 2.5 22.5 12.5 10.5 14 M12x1.0 in. 0,55 0,63 0,10 0,89 0,49 0,41 0,55 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FAA.1S.650.CTA 价格&库存
很抱歉,暂时无法提供与“FAA.1S.650.CTA”相匹配的价格&库存,您可以联系我们找货
FAA.1S.650.CTA
  • 1+382.398461+49.61589
  • 10+325.0509310+42.17509
  • 30+300.8077030+39.02955
  • 50+290.1671250+37.64895
  • 100+276.33115100+35.85374
  • 250+259.05493250+33.61217
库存:74
FAA.1S.650.CTA
    • 1+396.846131+51.00008
    • 10+343.9310510+44.19978
    • 25+303.4695825+38.99993
    • 50+271.5263150+34.89479
    库存:98
